How Do You Lift the Front Wheel Off the Ground?
- bountyhunter
15 Apr 2008 13:28
I used to have these really cool crash bars that bolted onto the engine front on my 750 twin. I could use the cross tube to lift the front end. Put it on the center stand then lift under the tube, no problem
Now I have mac 2-1 headers and the crsh bar won't fit on because the MAC pipes stick too far forward at the bottom where the pipe turns rearward. No reason except they were too lazy to put a longer smooth radius bend there, they just use a short right angle bend and the ,ower portion of the pipe sticks far out.
So, I can't use the crash bars and the pipes also run under the frame tubes.
I know you can't jack under the oil pan, I know there are aftermarket jacks that mate with the frame (which the pipes block anyway).
Not sure what the best thing to do is, sure don't want to have to pull the pipes every time I need to raise the front.
Anybody know if there are bolt on bars which will clear the stupid MAC pipes?
- ronjones
Re: How Do You Lift the Front Wheel Off the Ground?
15 Apr 2008 13:44
I've been lifting my front end w/a come-along, hooked to a rafter, in garage, and the handle-bars.
15 Apr 2008 13:57
a 2x4 under the motor will distribute the weight evenly and allow you to use a bottle jack without harming you engine.
- KZ250LTD
Last edit: 07 Feb 2013 03:07 by KZ250LTD.
- moneypit
15 Apr 2008 15:18But the come along sounds like the best bet.
2-76 kz900
St Paul MN
St Paul MN
- bountyhunter
15 Apr 2008 16:23
KZ250LTD wrote:
So you use the rear wheel and center stand as a tripod stand?
Never thought of that.
Doubt I would ever have the nerve to try it....:blush:
If you don't need it too high and the bike has a center stand, pop it up on the center stand and throw some sandbags on the back of the seat. I have a lift but I used this method for switching out the forks on my 750
- bountyhunter
15 Apr 2008 16:23
ronjones wrote:
Good point, but I dont have one and the rafters in my garage are too rickety.I've been lifting my front end w/a come-along, hooked to a rafter, in garage, and the handle-bars.
- bountyhunter
15 Apr 2008 16:25 - 15 Apr 2008 16:25
531blackbanshee wrote:
I'll admit that's what I was thinking (wood block). Cutting one a bit to get it to fit the oil pan and then use my floor jack under it....a 2x4 under the motor will distribute the weight evenly and allow you to use a bottle jack without harming you engine.
Last edit: 15 Apr 2008 16:25 by bountyhunter.
- rdgrnr
15 Apr 2008 16:32
bountyhunter wrote:
I used the floor jack and 2x4 under the motor to take the front off of the 1000...worked just fine.
531blackbanshee wrote:I'll admit that's what I was thinking (wood block). Cutting one a bit to get it to fit the oil pan and then use my floor jack under it....a 2x4 under the motor will distribute the weight evenly and allow you to use a bottle jack without harming you engine.
77 KZ650B1
80 440 LTD Sold
78 GL1000 Naked Wing Sold
80 CM400E Sold
Brainerd, MN
80 440 LTD Sold
80 CM400E Sold
Brainerd, MN
- steell
15 Apr 2008 16:45
I've been doing it for years, and on a bunch of different bikes, usually with a floor jack but sometimes with a bottle jack.
Never caused a problem
15 Apr 2008 17:12 - 15 Apr 2008 17:14
Maybe not applicable on the 750 twin, but on the large fours, I use a short length of 2x4 with a shallow hole drilled in it which fits snugly around the oil plug and keeps the 2x4 held in position under the engine whether using floor jack or bottle jack.
Last edit: 15 Apr 2008 17:14 by Patton.
- PLUMMEN
15 Apr 2008 17:27
