problem mounting my rear wheel
- XL777
Re: problem mounting my rear wheel
14 Apr 2008 16:44
2012 Triumph Bonneville SE black
1978 KZ1000 B2 LTD
Fresh top end rebuild
Rebuilt head
Wiseco 1015 pistons
Dyna s
Green Dyna coils
Wired george mod
It is easier to say what I haven't replaced then what I have.
I must love this cruel mistress since she hates me
1978 KZ1000 B2 LTD
Rebuilt head
Wiseco 1015 pistons
Dyna s
Green Dyna coils
Wired george mod
- PLUMMEN
14 Apr 2008 18:38
XL777 wrote:
worked in our case anyway:)
when we did it we just removed the bolts/slides and installed them after caliper was on.Great input everyone. However, on my bike yes I did have to remove it allit was a biatch to do, but I learned a lot. The reason it all had to come off was due to the fact the caliper is mounted to a bracket and that is mounted on the axel. As well the head of the axel was placed on the right side rather then the left side, making removing the axel nut and sliding the axel out part way not possible. Believe me if there was any other way to do this I would have. I even bought the wrong pads because my bike is "special" the clymer manual doesn't even make reference to my bike haha.
- RonKZ650
14 Apr 2008 19:50
I'm still at a little loss as to the axle thing fixing the washer problem. According to your pictures the axle is now in opposite of how it's supposed to be. From the factory the bolt went through from the left side with the nut on the right side, but even so it makes no difference really. The washer is outside the chain adjuster placed on right before the axle nut.
- XL777
14 Apr 2008 19:56
You are right it is on the wrong side, thus why I was having a problem reading the diagram. For some reason the last owner had it set up that way, so when I put it all back together I put it back the way I found it. That is why when I looked at the diagram the damn washer was on the right side. LOL I'm too lazy to change it now, so if I have to do it again I will correct it.
1978 KZ1000 B2 LTD
Rebuilt head
Wiseco 1015 pistons
Dyna s
Green Dyna coils
Wired george mod
1978 KZ1000 B2 LTD
Rebuilt head
Wiseco 1015 pistons
Dyna s
Green Dyna coils
Wired george mod
- rdgrnr
14 Apr 2008 20:35
According to Kawi, the same rear caliper was used on all 77-80 Ltd's and 80 G1. And by my Kawasaki 1000 service manual, all that was needed to change pads, was too flip up the cover, and remove the clips and pins. I also have the 79 supplement, and it states that the procedure is the same as the manual states. Well, it looks like you are learning as you go, which is what I pretty much as I had to do.
Have funB)
Have funB)
77 KZ650B1
80 440 LTD Sold
78 GL1000 Naked Wing Sold
80 CM400E Sold
Brainerd, MN
80 440 LTD Sold
80 CM400E Sold
Brainerd, MN
- XL777
15 Apr 2008 19:09
Moral of the story. There is always an exception to the manual and to the norm
It is all set up now. One problem down too many to list to go
1978 KZ1000 B2 LTD
Rebuilt head
Wiseco 1015 pistons
Dyna s
Green Dyna coils
Wired george mod
1978 KZ1000 B2 LTD
Rebuilt head
Wiseco 1015 pistons
Dyna s
Green Dyna coils
Wired george mod
15 Apr 2008 21:00 - 15 Apr 2008 21:14
I believe XL777 is correct in needing to remove the rear wheel to change the brake pads on his '78KZ1000LTD, because its rear caliper has no removeable pad cover and is a different design than the standard model rear caliper with removeable pad cover.
The '78KZ1000LTD rear caliper looks virtually identical to the '76KZ900LTD rear caliper whose FSM supp. instruction for rear caliper pad replacement begins
Step 1. Remove the rear wheel.
In this case, the disc must be removed from between the pads in order to remove and replace the pads. Attempted disassembly of the LTD's rear caliper to remove it from the holder and allow pad replacement without removing the wheel would likely ruin the internal rubber dust covers and other rubber parts fitted around the slider bolts. If there's a way to remove and replace the slider bolts without damaging and displacing the internal rubber parts, I haven't figured it out yet.
Here's the '78KZ1000LTD rear caliper.
Last edit: 15 Apr 2008 21:14 by Patton.
