O Ring chain install ??
  • BSKZ650
  • BSKZ650's Avatar Topic Author
12 Mar 2008 05:42
#199674
I was trying to install the master link last night, I cannont get it to compress enough to put the clip on, vise grips dint work, any ideas
This is a R K 530 chain, they show a tool on there site, just hate to spend $110.00 for a tool that dosent get used much
77 ltd1000, current rider
76 kz900, just waiting
  • Bluemeanie
  • Bluemeanie's Avatar
Re: O Ring chain install ??
12 Mar 2008 06:01
#199682
Funny you should say that. Same here, I used vice grips to compress link and then after link on they want you to force link back out against master link. But they say "DON'T USE VICE GRIPS" The VG's should work, did you use two VC's? One over each pin, that's what I did. Let us know.
  • mariozappa
  • mariozappa's Avatar
12 Mar 2008 06:11
#199689
I bought one of these from dennis kirk.
It's $14.99
Chain press tool:
denniskirk.com/jsp/product_catalog/Produ...54&leafCatId=&mmyId=
1977 KZ650C1
and the KZ650/KZ750 Conversion ;)
  • davenkids2001
  • davenkids2001's Avatar
12 Mar 2008 06:21
#199696
Be careful using vise grips to compress this link. I am a bit surprised that they sold you a C-Clip type master link at all...my local dealership won't sell the C-Clip type due to the possibility of it coming loose.
Last year I replaced my chain with a stock replacement and found that Kawasaki will NOT provide the C-Clip style master link. I ended up renting (for $10) a tool from the dealer to properly set the rivet-style link that was included with the new chain.
Yeah...I've used the C clip style in years past w/o any problems, but for a few bucks extra I found peace-of-mind utilizing the rivet style link.
Just my 2 cents...
YMMV
(Your mileage may vary...)
-Dave
Dave and Janet
Great Lake State
1979 650SR
  • RonKZ650
  • RonKZ650's Avatar
12 Mar 2008 07:02
#199709
Vise grips work fine. Put your new masterlink plate on, then your old masterlink plate on top of it. This builds up the thickness of the plate enough to: A-not damage your plate and B- builds the plate up so the pins do not interfere with the clamping.
Put both plates on, clamp with vise grips, then your old plate is pried off leaving the new plate fully pressed on.
For 50 yrs we have all read how dangerous these master links are as they can come off but I have never heard of it actually happening. Once the plate is clamped on, it's not going to come off. The clip is then installed for added security. The clip is just that, an added security, like the kotter pin on your axles, the plate isn't going anywhere if you clamp it on correctly.
  • Locozuna
  • Locozuna's Avatar
12 Mar 2008 10:49
#199730
Ron's way is the way I was taught to do it. Pretty ez and never had a failure.
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
  • The Milkman
  • The Milkman's Avatar
12 Mar 2008 11:56 - 12 Mar 2008 11:57
#199741
I've never had any problem using the clip type either. The only way I can think it would come off is if it isn't put on all the way to begin with. I will add this though....
YOU WANT THE ROUNDED END OF THE CLIP FACING THE DIRECTION OF ROTATION!!!!!!
When the master link is on top of the sprocket, you want the round end of the clip facing toward the front.
Ride Safe
Last edit: 12 Mar 2008 11:57 by The Milkman.
  • BSKZ650
12 Mar 2008 12:33
#199750
Thanks, I just went to a bike shop and purchased one of the install tools like Mario showed, cost me 17.00 but it was local,maybe tonight I will get this back on the road
  • KZDon
  • KZDon's Avatar
12 Mar 2008 16:54
#199797
My parts guy and my office I.T. guy came up with a solution, partly because my parts guy wouldn't cell me a C-link.
I borrowed the I.T. guy's big bench vise, put it under the KZ, and using the old link over the new link for protection, cranked on the vise until it was partially set. Then, using the side of vice as an anvil, set the pins properly with a ball peen hammer.
The bigger problem was removal. It took the better part of an hour and some serious body contortions to dremel the pins down enough to pop the old link.
BTW, chain break and repair tools are fine for bicycles, but in my experience, you get what you pay for with a $17.99 tool. My attempt with one was a failure damaging the new chain too much to be usable. The tool itself had to be dremelled out, so it was garbage too.
Midland, Ontario, Great White North
2004 650 V-Strom
farewell to 81 KZ550A2 - 82 GS750T - 83 GPz750 - R-Reg GT380 - 76 DT175 - 84 GPz550
  • mariozappa
13 Mar 2008 06:20
#199860
I have put on 3 chains with that tool, seems to work well so far.
I should have mentioned:
I use a box end wrench over then end of the allen wrench for extra leverage when installing the plate. It takes a little bit of muscle.....and leverage.
1977 KZ650C1
  • BSKZ650
13 Mar 2008 10:20
#199899
What a differance the right tool makes, I had the chain back together and the bike on the road in less than 30 min, I fought the damn thing for over a hour the night before
  • hmondo
  • hmondo's Avatar
13 Mar 2008 14:28
#199925
On a slightly different note although along the same lines, removing the old chain off of my Police bike was a piece of cake. Since the chain had no link (continuous), I cut it with a cutting wheel using my die grinder. Like a hot knife through butter. I expected the steel on the chain to be harder!
1989 KZ1000 P-8 (Police)
1987 ZL1000
1986 Concours (Project Bike)
