Ripped seat cover in crash.
  • Qdude
  • Qdude's Avatar Topic Author
  • It is all good.
04 Mar 2008 11:38
#198360
Yea I really did a number on my girl, and I have a heck of a lot of posts on a lot of different problems.
But hey, a crash is a crash and we tinkerers must fix!
What is the best source for material to recover a seat?
I imagine that the existing seat material can be removed and used as a pattern to cut the new cover. I realize that the cover material will not be a flat piece but contoured. Perhaps stretchable?
How tough is it to replace the foam? From scratch?
What experiences have there been all?
Holy seat cover Batman !!
P.S. I have access to a sewing machine and could figure out the dimensions of the contour.
Post edited by: Qdude, at: 2008/03/04 14:40
77 KZ 650 C1.
77 KZ 650 C1.
  • JMKZHI
  • JMKZHI's Avatar
Re: .
04 Mar 2008 12:33 - 04 Dec 2008 05:45
#198374
del
Last edit: 04 Dec 2008 05:45 by JMKZHI.
  • ronjones
  • ronjones's Avatar
Re: Ripped seat cover in crash.
04 Mar 2008 14:52
#198398
Well, it kinda depends on if you want "authentic" or cheap. I've taken material and just streached it on top of a seat that had cracked material. Didn't look all that great but it worked. I also found a fabric, in Walmart, I think, that's like a real high quality "raincoat" kind of material. Kinda streachy w/a "rough" texture. I used this on a seat I tried to rebuild from scratch foam. I think the material would be good but I didn't do a very good job on the foam carving, so that's a project I'm going back to. I was able to get a good replacement seat so I've set that aside. If you have some "chunks" of foam that have been destroyed you could carve out the bad areas and replace w/foam cut to fit. Just a couple of ideas.
  • The Milkman
  • The Milkman's Avatar
04 Mar 2008 15:14
#198402
Check THIS out. May be an alternative for you and the price isn't bad. There are some reviews for it too. Also, there is a foam kit at the bottom of the page after you click on the cover kit.
Post edited by: The Milkman, at: 2008/03/04 18:16
  • Vter Bob
  • Vter Bob's Avatar
04 Mar 2008 15:15
#198403
Georgia, Vermont
1981 KZ550 LTD
1982 KZ1000 LTD
1999 ZG1000 Concours
Greetings from the Peoples Republic of Vermont, home of Ethan Allen, 2 American Presidents, a socialist US Senator and.....Homer & Bart Simpson
  • Vter Bob
  • Vter Bob's Avatar
04 Mar 2008 15:47
#198409
errrrrrr........oops!
Post edited by: Vter Bob, at: 2008/03/04 18:49
Georgia, Vermont
1981 KZ550 LTD
1982 KZ1000 LTD
