shifter wont tighten.
- mpatrick19
- 1982 kz750 spectre
- OKC_Kent
Re: shifter wont tighten.
22 Jan 2008 17:47
Are you saying you can't tighten the bolt, or that the shifter moves around no matter how tight the bolt is?
Post edited by: OKC_Kent, at: 2008/01/22 20:49
Cashion, OK
78 KZ650 B2 85,000+ miles
- Bluemeanie
22 Jan 2008 19:08
Funny you should mention that. Cycle World had a tech tip about just that! I can't find that mag now but they say to file off the first spline on each side of the gap on the inside of the shifter. They say instead of tightening, the first splines actually bind against the splines on the shifter shaft preventing compression. Removing the couple splines allows it to compress more.
Post edited by: Bluemeanie, at: 2008/01/22 22:08
- mpatrick19
22 Jan 2008 19:52
it just spins no matter how tight i get it. i was thinking of filing down the flat spots where it comes together to get to more compression out of it. Also it i cant get this to work how hard is it to change the shifter shaft. the bike is an 82 kz750 n1, shaft drive if that makes a difference.
thanks, mike
thanks, mike
1982 kz750 spectre
- Bluemeanie
22 Jan 2008 20:28
Are the splines worn off the shifter shaft or the foot shifter? (please, please let it be the foot shifter!)
- mpatrick19
23 Jan 2008 05:52
its the splines on the shaft.
1982 kz750 spectre
- Bluemeanie
23 Jan 2008 06:06
It should be changed but I know guys that have installed shifter, tightened down and then have someone mig weld on exposed end. Works great until you have to remove side cover! I guess that would be the time to fix it. I've never changed a shift shaft, someone else will have to chime in on that one. Sorry dude.
- BSKZ650
23 Jan 2008 06:24
I saw this years ago, and it worked on a drag bike.
locate the position you want the shifter to be in, scribe a line on the shaft and shifter, use a die grinder to make a slot for a key in the shaft and on the shifter, you can get key stock at any hardware store, I am guessing a 1/8 key would work, install the key and shifter and lock into place.
77 ltd1000, current rider
76 kz900, just waiting
- RonKZ650
23 Jan 2008 06:32
Also kind of a similar idea is to drill through the lever, then partially through the shaft itself, then tap for a small bolt. Doesn't take much to hold it. I did this once on an old dirt bike and it did the trick just fine. Otherwise the shift shaft is used on many models and should be still available and not all that hard to replace.
- kzwolfsr
23 Jan 2008 06:35
Very good idea BSKZ, but I was thinking Ron's idea before he posted. O well!
Original man of the Caribbean
- BSKZ650
23 Jan 2008 07:09
Rons idea sounds like a lot less work, should hold it quite well
- The Milkman
23 Jan 2008 07:13
It won't work if either the shaft or lever are worn smooth but if they aren't some thin brass shim stock to fill the gap would work just fine and you will have no problem removing the lever when you have to in the future.
And it doesn't have to be brass, a strip cut out of a beer can would work just as well. And it's a good reason to have that beer:laugh: :laugh:
Post edited by: The Milkman, at: 2008/01/23 10:19
