shifter wont tighten.
- FloridaBiker
Re: shifter wont tighten.
23 Jan 2008 09:05
There is another solution.
Just tack weld the shifter to the shaft.
You can easily grind off the tack weld to remove.
It sure beats splitting the cases.
23 Jan 2008 09:31
take a die-grinder with a cutoff wheel and pass it through the gap on the shifter where it tightens up.that will give you more room to be able to tighten it up all you need,by removeing enough material to clamp tighter.i have done this on many bikes and quads.
- Locozuna
23 Jan 2008 10:12
I'd do the tack weld and make sure to carry a set of vice grips for a temp shifter if it ever fails on a ride. Just make sure you don't have to get to the sprocket or your clutch cable in the NEAR future, but even so you should be able to grind off the tack easily.
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
- steell
23 Jan 2008 12:22
FloridaBiker wrote:
Why would he have to split the cases? The shift rod is on the outside of the cases.
- OnkelB
23 Jan 2008 12:34
Yeah, like Steell says, no need to split the cases - just remove the mission cover and you can replace the shift shaft/gear selector from the outside:
Post edited by: OnkelB, at: 2008/01/23 15:40
77 KZ 650 B1, 82 GPz 1100 B2.
- OnkelB
23 Jan 2008 12:35
Dang....
:pinch: Please delete.
Post edited by: OnkelB, at: 2008/01/23 15:49
- OnkelB
- OnkelB
23 Jan 2008 12:44
:pinch: Please delete again.
Post edited by: OnkelB, at: 2008/01/23 15:50
- OnkelB
- OnkelB
- mpatrick19
- 1982 kz750 spectre
23 Jan 2008 18:25
i tried to file some of the gap to make it tighten more, didnt work i dont think i did it enough. im gonna try it some more if that doesnt work i might try and drill through the shifter into the shaft, if not im breaking out the welder.
thanks for all the responses.
- mike
- mike
1982 kz750 spectre
