chain length?
  • Fatrubber
  • Fatrubber's Avatar Topic Author
chain length?
09 Jan 2008 15:01
#188461
I am in the process of putting a 6 in. over swingarm on my 900 and was wondering if anyone may know how long of a chain i will need? i am planning on running a 15/38 combo on sprockets. thanks
Lite'm up and burn'em down
  • The Milkman
  • The Milkman's Avatar
Re: chain length?
09 Jan 2008 16:11
#188468
If you are going 6 inches longer you will need one a foot longer than the original if you were using the original sprockets. How much difference is in the 15/38 than the original?
Ride safe.
  • Fatrubber
Re: chain length?
09 Jan 2008 16:50
#188474
the stock ones or at least the ones on it are 15/35, not sure on the stock number of chain links though. thanks for the help
  • love2ride
  • love2ride's Avatar
  • Ngati Tumatauenga
Re: chain length?
09 Jan 2008 20:47
#188505
Stock gearing is 15/35.
Stock chain is 630/92 links.
Newport News, Va
2006 Ninja 250 - Commuter
1978 KZ1000 - Not even close to stock.
  • The Milkman
Re: chain length?
09 Jan 2008 21:21
#188507
A 630 chain with 92 links would be 69 inches long according to my calculator. 92 * .75 being the spacing on the pins of 630 chain. So adding a foot, 12 / .75 would be 16 more links or a total of 108 links.
If you switch to 530 chain it would be, length of 81 /.625 the length of a 530 link or 129.6 links. A 128 or 129 link chain should work fine. If I'm wrong I'm sure someone will chime in.
Ride safe
  • Fatrubber
Re: chain length?
10 Jan 2008 16:02
#188608
thanks for the help i will try to get some pics one here when it get it done.
  • madkaw1200
  • madkaw1200's Avatar
Re: chain length?
14 Jan 2008 13:14
#189245
hi
i have a 3 over on my kz 1000 it has a 630 o ring chain that is 100 pins, i have a 6 over on my other kz 1000 and it has a 630 o ring with 110 pins.im not sure but if you go with a none o ring chain the length may be shorter.hope this helps.
sunny south roxana illinois
80 kz 1000 (1105 kit)
79 kz1000 (1075 kit)
76 kz 900 (1200 kit):woohoo: :evil: B)
  • jagrider
  • jagrider's Avatar
Re: chain length?
15 Jan 2008 07:34
#189395
You may take tape ruler and run it around the front and rear sprockets and add 3 more inches and give your suppliers how long it is they should be able to match it from that. It's always good to have a little more than you need you can always take a few links out. My bike swing arm rear tire is about 3" longer than stock. my 630 chain is 78 inches long 16/40 gears. I move to a 525 chain.
Good luck B)
Post edited by: jagrider, at: 2008/01/15 10:54
Loud pipes save lives.
  • Jeff.Saunders
  • Jeff.Saunders's Avatar
  • Vendor
  • Vendor
Re: chain length?
15 Jan 2008 09:01
#189412
Measure the center of the output shaft to the center of the axle in inches. Divide by .75 and double (for top and bottom).
i.e (28" / .75") x 2 = 74.67 links
Count the number of teeth on both sprockets and halve this count.
i.e 15 + 35 = 50 / 2 = 25 links.
So roughly 99.67 links or 100 links in this example (remember you have to order in even number of links). You need to add a small amount for the difference in sprocket sizes although this ends up being an insignificant amount in the scheme of things (99.67 versus an accurate number of 99.94 links).
If you want to call us, we go through the calculation a little more accurately with a utility that calculates this very accurately based on the sprocket sizes and the distance between the outputshaft and rear axle.
  • 79MKII
  • 79MKII's Avatar
  • Love Them Kaws!
Re: chain length?
12 Aug 2008 18:50
#231677
OK, kind of reviving an older thread here...
Regarding chain length - I want to add more teeth to my front and rear sprockets while keeping the same chain size and swingarm length.
Do I simply need as many more links as I'm adding teeth??
For example, let's say I have a 15t front and a 35t rear (50 teeth total). I would like to go to a 18 front and a 42 rear (60 teeth total). Do I need a chain that is 10 links longer?? That seems too long.
Maybe add 1/2 of the extra teeth? Would I need 5 more links for this change? I used to know this stuff - it's hell getting old...:S
The Kaw List:
  • Belliott
  • Belliott's Avatar
Re: chain length?
12 Aug 2008 20:05
#231697
Hi, new rider here (just passed MSF course still need license). Just for s**ts and giggles what exactly does adding extra inches to the swingarm do to the ride? Just curious.
  • 79MKII
  • 79MKII's Avatar
  • Love Them Kaws!
Re: chain length?
12 Aug 2008 20:52
#231702
Welcome! The main idea is to limit wheelies for a quicker launch when drag racing. It also adds high speed stability. The drawback is that it usually hurts the performance in the corners. And, of course...it LOOKS COOL!!:) :laugh:
The Kaw List:
