OK - I think I found the answer. If I'm reading the article correctly, it is 1 link of chain per 2 new teeth on sprockets. Here it is from Z1E:
Changing sprocket sizes may effect chain length. As roughly 1/2 of each sprocket has chain touching it, each tooth added to stock sizes will require approximately 1/2 link of additional chain. Increasing total teeth by one or two teeth can usually be accommodated by moving the rear axle forward slightly and keeping the stock chain length - but if you start changing sprocket sizes more than one or two teeth, you will need to increase chain length. Going up four teeth will require a chain 2 links longer.
The Kaw List:
Last edit: 17 Aug 2008 16:42 by 79MKII.
