Smaller rotor?
- loudhvx
Re: Smaller rotor?
23 Nov 2007 13:03
Bluemeanie wrote:
Hey that looks identical to the way I did it at my buddies machine shop years ago!
The trick to seeing how well you did is to assemble the front end, then loosen the pinch bolts on one leg and spin the tube. If it spins freely all the way around, it's straight. If it binds real hard at one point, it's still bent. It's almost impossible to get it perfect. Mark the tube as to how it's bent and try to install it with the bend going forward. That way it'll straighten as you apply the brakes.
Not a problem KaZoo, guess you didn't catch my post in chassis. Another member here (jjdwoodman) bent his forks in an accident and he straightend them. We pm'd and he told me how he did it. Well being a mechanic I have access to a 40 ton press so I used the 1 1/2" (38mm) dies from my pipe bending machine and pressed away! Ahter about 1 1/2 hours I had it just about perfect (straight edge on 4 sides)! So I'll be installing my factory front end, just need to hunt down a triple tree. Thanks for the offer, I really appreciate it.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- shortyyyyyy
Re: Smaller rotor?
24 Nov 2007 16:28
Bluemeanie wrote:
reply sent-- if I figured out how to reply... if not, postage is the only cost!- assuming I find it tonight:side:
shortyyyyyy, PM sent!
- Bluemeanie
Re: Smaller rotor?
24 Nov 2007 20:45
You did fine, take your time... John
