Smaller rotor?
  • Bluemeanie
  • Bluemeanie's Avatar Topic Author
Re: Smaller rotor?
15 Nov 2007 15:43
#181230
Not a problem KaZoo, guess you didn't catch my post in chassis. Another member here (jjdwoodman) bent his forks in an accident and he straightend them. We pm'd and he told me how he did it. Well being a mechanic I have access to a 40 ton press so I used the 1 1/2" (38mm) dies from my pipe bending machine and pressed away! Ahter about 1 1/2 hours I had it just about perfect (straight edge on 4 sides)! So I'll be installing my factory front end, just need to hunt down a triple tree. Thanks for the offer, I really appreciate it. :)
  • SLEEPER650
  • SLEEPER650's Avatar
Re: Smaller rotor?
15 Nov 2007 17:24
#181245
Well i have a triple tree set off of an 80 750 do you know if it will work?
78 650sr my baby
78 650sr waiting for rebuild
82 kz1100
  • Bluemeanie
Re: Smaller rotor?
15 Nov 2007 18:56
#181263
Thanks SLEEPER650 but according to Kawasaki.com only the bikes below share the tree with my bike. :( I appreciate the thought... :)
KZ650-B1 (1977)
KZ650-B2 (1978)
KZ650-B2A (1978)
KZ650-B3 (1979)
KZ650-C1 (Custom) (1977)
KZ650-C2 (Custom) (1978)
KZ650-C3 (Custom) (1979)
KZ650-D1 (SR) (1978)
KZ650-D1A (SR) (1978)
KZ650-D2 (SR) (1979)
KZ650-E1 (LTD) (1980)
KZ650-F1 (1980)
  • mariozappa
  • mariozappa's Avatar
Re: Smaller rotor?
16 Nov 2007 05:59
#181305
Do you need the whole triple tree, or just the top, or just the bottom?
Btw, The 750 triple tree holds the 36mm forks at slightly wider stance, so they wont work.
I found out the hard way.
Post edited by: mariozappa, at: 2007/11/16 09:04
1977 KZ650C1
and the KZ650/KZ750 Conversion ;)
  • Bluemeanie
Re: Smaller rotor?
16 Nov 2007 07:45
#181316
Right side upper and lower clamps are perfect. Left lower is tweaked slightly, thought about bending it but upon sliding a fork up to the upper clamp it's off by 2 inches down by the wheel. So upper is real bad and so figure just get the entire tree. Bottom may be tweaked more than I think.:dry:
  • mariozappa
Re: Smaller rotor?
16 Nov 2007 07:47
#181317
Let me rummage around through my piles of parts and get back to ya on monday....
1977 KZ650C1
  • Bluemeanie
Re: Smaller rotor?
16 Nov 2007 07:54
#181318
Thanks mariozappa, yu da man! :)
  • SLEEPER650
Re: Smaller rotor?
16 Nov 2007 17:19
#181391
to bad you didnt see this one ebay#230173343680
78 650sr my baby
82 kz1100
  • Bluemeanie
Re: Smaller rotor?
16 Nov 2007 17:26
#181392
Not too bad sleeper, my budget is kinda tight and with shipping from Canada it could get pricey. But thanks for the thought.. :cheer:
  • mariozappa
Re: Smaller rotor?
19 Nov 2007 08:38
#181723
I'm supposed to go look a some rims this weekend..maybe.
The guy says he also has a 650 frame with various
triple trees and front ends. I don't think he knows what he has.
So, we'll see.
I looked in my parts, and the only extra 650 triple tree I have has a nasty gouge in the shaft from the lower set of ball bearings. I really don't know if filling it in and using roller bearings instead of plain would be ok or not.
I'll have to see what this guy has.
1977 KZ650C1
  • shortyyyyyy
  • shortyyyyyy's Avatar
Re: Smaller rotor?
20 Nov 2007 06:02
#181841
I'll take a couple minutes later today (gonna be 70+) and dig for my other set of trees-- '79 650D2. I cannot vouch for integrity, but on initial inspection, they looked good enough to keep as a spare when they came unexpectedly with the forks I got from Ebay (forks and trees for $30.00) If you still need 'em- lemme know this evening and we'll make arrangements.
  • Bluemeanie
Re: Smaller rotor?
23 Nov 2007 12:43
#182357
shortyyyyyy, PM sent! :)
