just cleaned the tach drive housing...
- NickW900LTD
- Nick
24 Oct 2007 23:57
Waiting on orings to come in mail, is there anything special i should do before putting the new orings back in?
Nick
Nick
1976 KZ900 LTD (sold)
1977 KZ1000 LTD
1978 KZ1000 A2A
Pierceton, Indiana USA
1977 KZ1000 LTD
1978 KZ1000 A2A
- racer54
Re: just cleaned the tach drive housing...
25 Oct 2007 00:48
I'd just check to be sure there isn't any burrs, etc. in the drive mount area and be sure you clean it really good. It can get gummed up in there over time. Make sure everything moves freely once you are ready to re-install everything.
- NickW900LTD
- Nick
25 Oct 2007 09:12
Patton wrote:
yes i bought one of those too. Im taking it to work today and im going to soak the housing in some caustic acid to help clean it up better.
1977 KZ1000 LTD
1978 KZ1000 A2A
1977 KZ1000 LTD
1978 KZ1000 A2A
25 Oct 2007 11:51
After thirty years of living in an enviornment of heat and hot oil, the old inner seal seemed hard as a piece of carbon and was difficult to completely remove from inside the housing. But patiently kept picking at it, and it finally come out bit by bit, including the tiny metal spring fitted around the seal.
Good luck with the repair and enjoyment of an oil-tight tach drive.!
- ltdrider
25 Oct 2007 13:23
That tach drive is REAL hard to install with new oring seals. But it's worth it once you finally get it in. Zero leaks.
Be very careful not to cut or shave the oring during installation. Grease or oil the oring first, and be patient working it in.
'76 KZ900 LTD (Blaze)
'96 Voyager XII (Dark Star)
Greensboro, NC
Greensboro, NC
- NickW900LTD
- Nick
25 Oct 2007 20:56
i got it in and let it run for 10 minutes.......and not a drip!!!!! My first fix on the bike!!!
Oh, and the phillips screw had to be uncsrewed with vice grips. The head was stripped BAD. A guy at work gave me an allen screw and a 10mm hex screw to use for the housing. I decided to use the hex screw for I did not have a metric allen wrench. Also the caustic acid worked like a dream to rid the housing of excess rubber and cleanded it up real good!!!
Safe riding all!!!
Nick
Safe riding all!!!
Nick
1977 KZ1000 LTD
1978 KZ1000 A2A
1977 KZ1000 LTD
1978 KZ1000 A2A
