beefier kickstand for '79 KZ1000 ST?
- onanysunday
24 Sep 2007 09:57
Hello,
I have a '79 KZ1000ST-recently purchased. I noticed the kickstand is slightly bent, the bike leans to the left side a little lower than normal. All that is preventing its demise is a kickstand no thicker than my finger. My question..
Are there any other kickstands out there that will fit the stock mounting hole and spring tension post, perhaps another model with thicker gauge steel and a rubber foot on the end for added traction and stability? Any ideas?
If anyone has done this conversion, or has a part number, let me know, maybe I can find one on Ebay if I know what to look for. Thanks.
Post edited by: onanysunday, at: 2007/09/24 13:19
79 KZ1000 E-1
VM28SS
K&N Pods
VM28SS
K&N Pods
- barney
Re: beefier kickstand for '79 KZ1000 ST?
24 Sep 2007 11:03
Cant offer any help on a conversion. But to correct the lean problem you refer to. If its bent,could'nt you remove the thing from the bike,clamp it in a vice heat it up with an oxy/acytelene torch and straighten it out a little at a time till your happy? :whistle:
- ltdrider
24 Sep 2007 11:17
The KZ900LTD (1976) didn't come with a center stand because the pipes interfere. So Big K provided a beefed up side stand. Don't know about how it might fit on your frame. Also don't know how rare it is. And finally, I don't if other LTD models made after '76 (like the KZ1000LTD) also have a stronger side stand.
'76 KZ900 LTD (Blaze)
'96 Voyager XII (Dark Star)
Greensboro, NC
Greensboro, NC
- onanysunday
24 Sep 2007 15:30
Thanks for the recommendations!
79 KZ1000 E-1
VM28SS
K&N Pods
VM28SS
K&N Pods
- KZ_Rage
- Kentucky Bourbon Barrel Ale
26 Sep 2007 10:14
I have the same bike and pretty much the same lean. Don't worry about the lean unless is is excessive (photo?) As for the diameter of the shaft to the weight of the bike I wouldn't worry. Now if you're a fairly big guy and like to sit on the bike with the stand down then maybe... naw, the weak point is the frame fitting where it attaches, it is about a 3/16" thick piece of flat steel welded to the frame loop.
The foot size on the end of the kickstand is about normal for bikes built back then, get one of those plastic or metal kickstand coasters from eBay or a shop. You can use just about anything really though as long as it doesn't crush up under the weight of the bike on it. That'll save it from falling over on soft surfaces.
Oh and nice avatar! :lol:
Post edited by: KZ_Rage, at: 2007/09/26 13:15
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
2006 ZG1000A6F (Totaled)
2001 ZRX1200R (Sold)
1984 KZ550F2 SOLD!
- btchalice
26 Sep 2007 13:02
ltdrider wrote:
my 76 900 came with a factory centerstand that is currently on the floor of my garage because i replaced that section of the frame when i went with the monoshock
Terry Meyer / Wichita KS
76 kz900 w/1000 motor TWZTD
- shortyyyyyy
09 Nov 2007 07:19
onanysunday wrote:
have you gotten anywhere on this? mine's at the point where if it gets any lower, I'll be laying it on the case guard and the stand at the same time! I haven't had the occasion to park next to another KZ since I've had it so I'm at a loss as to what the correct angle of the stand and mount "should" be. The KZ has a 2"X6" flat on the ground under the stand and my V65 Magna still sits at less angle without the extra wood!
Any help will be appreciated!
--Shorty
Hello,
If anyone has done this conversion, or has a part number, let me know, maybe I can find one on Ebay if I know what to look for. Thanks.<br><br>Post edited by: onanysunday, at: 2007/09/24 13:19
--Shorty
- KZ_Rage
09 Nov 2007 15:23
Shorty, post a photo of yours so we can see if yours is about the same as ours or not.
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
1984 KZ550F2 SOLD!
- shortyyyyyy
09 Nov 2007 20:07
I'm still a computer retard-- I rely on my young, beautiful, computer genius wife to make these electric things talk to each other and do what I need 'em to (think I buttered her up enough to do it?)I'll take the pics, but it's up to her to make them get out of the camera. pics to follow......
[img=http://img112.imageshack.us/img112/9662/dscf1667pd5.th.jpg]
used Sporty instead of Honda, but same principal-- thanx to momma for the tech support
Post edited by: shortyyyyyy, at: 2007/11/09 23:46
Post edited by: shortyyyyyy, at: 2007/11/09 23:51
- Bluemeanie
10 Nov 2007 05:28
Have you checked the mounting tabs on the frame? After time the outer tab tends to get bent outward. The kick stand when wiggled with your hand may be very loose. I've used a hammer and tapped it back in. You may have a bent stand but check the tabs also.
If all else fails try this!!
tinyurl.com/yuy3uo
Post edited by: Bluemeanie, at: 2007/11/11 10:05
tinyurl.com/yuy3uo
- wiredgeorge
12 Nov 2007 12:38
When leaned over on side stand, the 79/80 KZ1000E1/E2 lean quite a bit farther than most any other KZ model. While the lean angle seems excessive, it is normal. Bending the OEM kick stand will not help. Although the OEM kick stand seems thin, it won't bend. I suspect the only way to resolve the problem would be to weld in about 2" of additional steel to the stock kick stand. Oh yeah, the bracket isn't bent either.
- shortyyyyyy
13 Nov 2007 19:18
KZ_Rage wrote:
would it be asking too much to get you to take a pic of your side stand in the "up" position looking straight down at it? Mine seems to stick out to the side an awful lot and is definitely banana shaped (to the point that only the "heel" of it touches the ground)
I know I'm gonna replace it, but still have to convince myself that it's bent!
