beefier kickstand for '79 KZ1000 ST?
  • FloridaBiker
  • FloridaBiker's Avatar
Re: beefier kickstand for '79 KZ1000 ST?
14 Nov 2007 06:09
#180997
I just had a 82 KZ1000 in my shop with a severely bent kickstand. It had the curve of a banana.
The owner was a big guy (over 300 pounds) and says he does not put his weight on the kickstand. (I guess it bent from fear he WOULD sit on it).
I straightened it with a oxy-acetylene torch, then mig welded a reinforcing brace to the side of the arm. I put it on the side facing the ground when the stand is up. I used a piece of1/2" angle steel.
I did not take a picture but here is a drawing of what I did.
Post edited by: FloridaBiker, at: 2007/11/14 09:10
Post edited by: FloridaBiker, at: 2007/11/14 09:11
  • shortyyyyyy
  • shortyyyyyy's Avatar
14 Nov 2007 11:30
#181047
O.K. so I'm safe in assuming that if the stand sticks out 3-4 inches to the side when it's UP that it's bent?
I don't mind replacing it, but as I've never had the occasion to see another KZ in person, and it's been this way since I got it, I didn't know for sure if it was supposed to be that way. Did the SR's with 16" rear wheel use anything special or will most stands be the same?
  • KZ_Rage
  • KZ_Rage's Avatar
  • Kentucky Bourbon Barrel Ale
14 Nov 2007 19:33
#181117
Sorry for the late reply, I'll grab a photo and post it soon.
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
2006 ZG1000A6F (Totaled)
2001 ZRX1200R (Sold)
  • shortyyyyyy
14 Nov 2007 19:49
#181121
no worries--I hope I didn't come off snotty. I appreciate anyone's help and definitely understand that time is at a premium. I've had the bike long enough that another day or so isn't gonna change much! Hell, I'm to the point that I've got blocks of wood at home, work, and various locations all around town so I don't have to carry one most of the time! ;)
  • KZ_Rage
  • KZ_Rage's Avatar
15 Nov 2007 17:25
#181246
snotty?? you gots a cold?! :laugh:
Here is the front view and the stand... tried to get as level as i could but then again it was me with a camera...
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
  • KZ_Rage
  • KZ_Rage's Avatar
15 Nov 2007 17:25
#181247
stand...
You can see more of the bike by looking for my "1979 KZ1000 ST Project" thread on this bike here in the Projects section.
Post edited by: KZ_Rage, at: 2007/11/15 20:28
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
  • shortyyyyyy
15 Nov 2007 19:35
#181272
thank you, thank you, thank you!! Mine's definitely bent as compared to yours. I noticed it was loose and was holding on to the hope that I could just squeeze the mounting ears together, but after seeing yours, I'm off to replace it! Way cool project, bye the way-- I'd have responded sooner except I got stuck drooling over your ride! Thanx again for the time to answer, and yes, actually, I do have a cold!:sick:
  • RonKZ650
  • RonKZ650's Avatar
15 Nov 2007 20:03
#181278
Mine is not bent like Kz_rage bike is. That stand is way bent. Mine is basically straight. My ST doesn't lean over hardly at all, but only has 4000 pampered miles on it.
  • shortyyyyyy
15 Nov 2007 20:41
#181281
well stinky poop on a stick! If his is bent, than mine's a pretzel!!! got a spare?
