1984 GPZ 750 brake problem
  • jcote75
  • jcote75's Avatar Topic Author
07 May 2007 07:55
#137858
Hi,
Went for my first ride this week end.
Everything was fine expect when I arrived at home. I've notice that I may have a problem with the front brake.
It brake well and don't pulse in the lever. But I've notice that the front suspension was going up and down at low speed.
Is this just the bad disk that need to be replace or it could be something else in the direction, wheel, or suspension.
Thanks for your advise!
Jocelyn
  • wireman
  • wireman's Avatar
Re: 1984 GPZ 750 brake problem
07 May 2007 12:28
#137932
im not really sure about your question;) if the front end dives id say check/replace fork oil;)
  • jcote75
07 May 2007 12:52
#137940
Yes your correct, the front end dive when braking at low speed. But it does it like the front disk would be waive (not sure if this is the correct term). Not a vibration but a slow up and down. I don't feel it when I brake at high speed.
  • BSKZ650
  • BSKZ650's Avatar
07 May 2007 13:16
#137953
do you have a pulse in the lever? when you are putting the brake on .
77 ltd1000, current rider
76 kz900, just waiting
  • jcote75
07 May 2007 13:24
#137958
Pulse!!!! that was the word I was looking for!
No pulse in the lever. But pulse in the front suspension. Feel like the disk wouldntt be straith or that the shaft of the front wheel would be damage. But this would cause pulsation all the time.
  • Fossil
  • Fossil's Avatar
07 May 2007 14:30
#137977
I wonder if the problem is the antidive?
  • RetroRiceRocketRider
  • RetroRiceRocketRider's Avatar
  • ...bring in the machine that goes PING!
07 May 2007 21:02
#138068
I was just going to suggest the same thing, since it basically "equalizes" pressure between the front brakes and forks.
I've heard of the anti-dive units leaking before, but never causing a "pulsating" feeling.
Ya never know though. ;)
jcote75,
Perhaps the pads and discs were very hot and causing the pulsating feeling. You did state that you noticed this when you arrived home after a ride.
Where you riding on a road with a lot of twisties (and/or in "stop-and-go" traffic) and using the brakes a lot? :whistle:
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
89 GSX1100F Katana = SLEEPING :-/
