Best way to get a tad bit of length out of forks
- Muddy
22 Apr 2007 14:36
I'm swapping shorter 77 kz650 forks onto my CSR, but it look like I may want to get an extra inch of length out of them. Is there an easy way to do this?
- steell
Re: Best way to get a tad bit of length out of forks
22 Apr 2007 17:44
The easiest way is to install a set of 78-79 KZ750 twin fork tubes, they are 1" longer.
- Muddy
22 Apr 2007 17:52
IS there any way to go with longer springs or a spacer inside the fork?
- steell
22 Apr 2007 18:06
Sure, you could put spacers made out of PVC pipe on top of the fork springs. Progressive Suspensions has a piece of PVC pipe inside their fork spring kits for that purpose.
Cost you $1.00 or less for enough PVC pipe to do both sides from any hardware store
Try to not go under 1" sag unloaded, that means that means the forks compress 1" from the point that the forks are fully extended (like bike on centerstand, front wheel in the air), to the point that the bike is standing normally without anyone on it.
Otherwise you will have to deal with some unpleasant bangs and thunks as the forks top out when you hit a bump or hole
Post edited by: steell, at: 2007/04/22 21:16
- Muddy
22 Apr 2007 19:10
What length PVC is the best bet? And then do you just open the fork up and drop it in? With the switch from leading axle to normal it brought the wheel back toward the pipes a little, just looking to get a bit more clearance. I don't need a ton.
Post edited by: Muddy, at: 2007/04/22 22:24
- wireman
22 Apr 2007 19:23
im guessing your csr has leading axle forks while the 650 does not which could cause some handling issues due to loss of trail in front end
- Muddy
22 Apr 2007 19:27
The wheel is moved back about an inch, I can't see that making a huge difference. It should make it steer quicker and maybe a tad bit nervous. Do you think it would make that much difference?
- wireman
22 Apr 2007 19:39
im not sure if it will quicken the steering up any,the rake which affects the steering most wont be changed.its the trail that gives you high speed stability that im wondering about;) probably wont be a problem,just want to make sure youre aware ofit is all;)
- Muddy
22 Apr 2007 19:49
What do you think about adding a steering damper into the equation?
- wireman
22 Apr 2007 20:03
that probably wouldnt hurt,whats wrong with your stock forks?
- KZQ
- Administrator
22 Apr 2007 21:43
Hi Muddy,
Actually, if you changed from a leading axle fork to a fork with the axle on the ends of the fork sliders you will increase your trail, cause an increase in steering effort and slow the steering down. That's assuming that you did not bring the triple trees along from the CSR as well.
Why do you think that you will need another inch of fork length? Even if the fork tubes are shorter, locating the axle on the end of the fork slider will be the same as adding an inch, or more, to the fork tubes. That's given that the fork sliders are the same length.
If you want to play with fork geometry check out the geometry calculator I uploaded to the file base. It's titled "MotoGeo".
KZCSI
Post edited by: KZCSI, at: 2007/04/23 01:08
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
- Muddy
23 Apr 2007 05:18
The forks that came on the bike were not originals, they were off maybe a kz750 twin. They were sticking up through the trees almost two inches and they were still a bit too long as the bike sat really high in the front end. I'm trying to convert the csr into a cafe racer, and couldn't run the forks that came on it with clubmans. late 70's KZ650 forks seem to be plentiful in my area so I went with those. The biggest reason that I need a tad bit of lenth is it looks like I may run into clearance issues between the tire and the pipes.
I'm not 100% on this yet because the wheel on the bike has a different sized axle than the spoke rim I'm putting on so the bike is still hanging from the trees in my garage.
