swingarm with original wheel
- austin3119
Re: swingarm with original wheel
16 Apr 2007 19:35
There's a guy on here, I think his handle is justlesh or something like that. Anyway he makes custom arms supposedly for about 250 or so. If you need more information let me know I will dig it up.
- wireman
16 Apr 2007 20:31
yeah they are steel though,i prefer the looks and strength of the aluminum ones myself;)
- 77KZ650
19 Apr 2007 03:13
wireman wrote:
get the 190 shinko. I have been talking to a few racers about the MT shootouts and shinkos. Ill be getting a 190 50 shinko ultrasoft. the shootouts are pretty much good for strip only cause they heat up and stick great after a burnout, but cool off too much and get hard and slippery during normal street use. the shinko is supposed to stay stickier for street use. they say to use 190 or 180 over the 200 as a 200 rounds up and has a smaller contact patch/footprint. the 180 and 190 get "stretched" a little flatter on the 6 inch rim and give you more of a contact patch. a few guys say to use 190, some 180, but both say that the 180 and 190 is better than the 200. plus the tire weighs less;)that one was from a 99 gsxr 750 im pretty sure.its all welded up now,ill get some new pictures of it when i get a chance;) that one is extend another 3" so its around 4-4 1/2" over stock plus it has enough room for a 200mm shootout tire with a 6"wire wheel.you can do wheelies with any length of swingarm this bike will have no problem melting down that tire and hoisting front end in any gear should i feel the need to do so;)
07 MDP Rookie of the Year
- AR15Ron
19 Apr 2007 04:42
if you had a wider swing arm how big of a tire could you put on a stock wheel? Say some lester mags?
- wireman
19 Apr 2007 10:44
77KZ650 wrote:
yeah im gonna run a shinko for puttin around town but im gonna have a shootout tire laces up on another wheel for when i decide to torture that poor 1/8 mile track across the bridge:evil:wireman wrote:get the 190 shinko. I have been talking to a few racers about the MT shootouts and shinkos. Ill be getting a 190 50 shinko ultrasoft. the shootouts are pretty much good for strip only cause they heat up and stick great after a burnout, but cool off too much and get hard and slippery during normal street use. the shinko is supposed to stay stickier for street use. they say to use 190 or 180 over the 200 as a 200 rounds up and has a smaller contact patch/footprint. the 180 and 190 get "stretched" a little flatter on the 6 inch rim and give you more of a contact patch. a few guys say to use 190, some 180, but both say that the 180 and 190 is better than the 200. plus the tire weighs less;)that one was from a 99 gsxr 750 im pretty sure.its all welded up now,ill get some new pictures of it when i get a chance;) that one is extend another 3" so its around 4-4 1/2" over stock plus it has enough room for a 200mm shootout tire with a 6"wire wheel.you can do wheelies with any length of swingarm this bike will have no problem melting down that tire and hoisting front end in any gear should i feel the need to do so;)
- wireman
19 Apr 2007 10:45
AR15Ron wrote:
id say a 130 is the limit for a stock rim;)if you had a wider swing arm how big of a tire could you put on a stock wheel? Say some lester mags?
- 77KZ650
20 Apr 2007 20:32
a few guys on here have fit a 140
