stator rotor
- Jeff.Saunders
Re: stator rotor
29 Oct 2006 09:22
Mark1122 - as WG said, the reg/rec would work, just it's not a direct plug-in for the later 79/80 bikes. Those bikes have a different connector block.
- mark1122
- Keep twisting it
Re: stator rotor
02 Nov 2006 06:17
Does the newer setup have enough power to run 2 headlights?
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- loudhvx
Re: stator rotor
02 Nov 2006 08:49
The bike should be able to handle two 55w headlights. If you are using a Dyna ignition, the Dyna uses more power than the stock ignition by about 55w. So a Dyna plus an additional headlight may drain the battery significantly at lower RPMs.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- mark1122
- Keep twisting it
Re: stator rotor
02 Nov 2006 15:13
Thanks .One of the other guys put 2 head lights on his 78 and they were not bright enough.So I wondered about the 79 &80's?
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
