stator rotor
- mark1122
- Keep twisting it
stator rotor
23 Oct 2006 17:06
My rotor has spun on the end of the crank and scored the crank end. I have decided to have the crank end removed and replaced ( about $85 plus a donor crank). The question is: If I should replace the 1976 end with a 1979 end will I have any issues with the new alternator? Can I just get another rotor and stator and cover and plug the new stator in the same way the old one was? Or am I going to have a wiring nightmare? I noticed on Z1 enterprises there rectifire/regulator upgrade was only good on the 76 style rotor years(73 to 78) The reason I would prefer the 79 is the bolt that holds on the rotor is larger and torques to 95 ft lbs. instead of 18 ft.lbs. on the 76.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- wireman
Re: stator rotor
23 Oct 2006 18:04
i dont think you can use newer style stator,i think end of crank is differant.i tried doing that on my red 78 a2 years ago and couldnt do it.maybe someone else has figured out how to make it work.
Post edited by: wireman, at: 2006/10/23 22:00
- mark1122
- Keep twisting it
Re: stator rotor
23 Oct 2006 18:51
the end is differant .I want to press out he old end and press in the new one.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- wireman
Re: stator rotor
23 Oct 2006 19:04
im guessing youre gonna split the cases and pull crank to do this,wouldnt it be easier to just swap cranks if you are going to all that trouble?
- mark1122
- Keep twisting it
Re: stator rotor
24 Oct 2006 15:16
Then I would have the added expence of a good crank versus an old crank with a good end for the donor, and a true and weld job.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- mark1122
- Keep twisting it
Re: stator rotor
26 Oct 2006 19:56
what if i went with the new style crank.will i have any wiring issuse??
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- wireman
- mark1122
- Keep twisting it
Re: stator rotor
26 Oct 2006 20:12
What exactly do you mean .Ijust got one for my 76 fron z1 enterprizes.but i noticed it didnt say 1979 80?
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- wireman
Re: stator rotor
26 Oct 2006 20:25
79-80 has a differant style stator,cover and reg/rec you have to match everything together;)
- loudhvx
Re: stator rotor
27 Oct 2006 10:00
As long as both bikes use 3-phase, permanent-magnet alternators, the 3-phase, solid-state combo reg/rec (meant for a 76 KZ 900) should work on both bikes, but you may have to splice wires if the connectors don't match up wire-for-wire.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- wiredgeorge
Re: stator rotor
27 Oct 2006 10:47
The 79/80 reg/rec will work fine with an early style stator/rotor set up. The 79/80 reg/rec has three yellow wires to hook to the AC off the stator, a brown sense wire to hook to any brown switched DC in the area of the stator, a black wire for ground and a heavier gauge white/red wire that is your DC out that splits and goes to the battery and 20A main fuse in. I have mixed a 79/80 reg/rec with an earlier style stator/rotor and the reverse and both work fine.
- mark1122
- Keep twisting it
Re: stator rotor
29 Oct 2006 08:28
Thanks guys .im sure this info will be important to others down the road when changing crank styles.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
