How to test a SH775 R/R
18 May 2026 17:46
My stator developed a short in one of the three legs. I bought a new one and it was putting out 13.5-14 volts while running but it stopped working like the last one in a couple months. I suspect it's in the R/R and how I should go about testing it.
- rstnick
Re: How to test a SH775 R/R
18 May 2026 18:34 - 18 May 2026 18:42
I'm also troubleshooting a charging system issue on my 1983 kz1000.
My system is over charging, so suspect the Reg/Rec.
Testing for it is here:
The Rick's Reg/Rec I bought has a list of checks to make before installing the new R/R.
Good to check all these items:
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
Last edit: 18 May 2026 18:42 by rstnick.
- rickysnicker
19 May 2026 05:51
19 May 2026 07:42
SWest is using a non-stock part, so I am not sure the factory tests will be valid, unless they are from one of the machines that came with that particular piece.
19 May 2026 07:46Are you currently using a 5 or 6 wire reg ? (does it have a brown ?) if 6 what is the voltage on the brown when the engine is running ?I'm also troubleshooting a charging system issue on my 1983 kz1000.
19 May 2026 07:59 - 19 May 2026 08:00
The SH775 is 5 wire.
Check the AC output of the alternator. There should be about 75 VAC out of each pair of legs. No load voltage is not definitive, but it's a good starting point. Test with the stator wires not connected to the bike otherwise. I've tested about two dozen SH775s and never saw a bad one. Make sure the stator feeds directly into the SH775. For output, you can either feed the power output direct to the battery, or split it, feeding both the bike and battery. This is the ideal hookup; from a Suzuki GS bike...
SH775 Install
by
nessism
, on Flickr
Last edit: 19 May 2026 08:00 by Nessism.
The following user(s) said Thank You: rstnick, SWest, 78kawltd, Wookie58
19 May 2026 08:07Ed my response was in relation to Rob's 1100R (didn't know if he was still on the OEM set up)The SH775 is 5 wire.
19 May 2026 16:22
The SH 775 is a series R/R not a shunt one like OEM. It is made to turn off one leg so as to not overcharge the battery while shorting one leg to ground that will in time burn out the stator (cause a short}. I have two but one doesn't seem to work now while the one I'm running stopped working. The last stator had a short on one leg. I fear this new one has gone the same way. It's now at 12.4vdc while riding.
Steve.
Steve.
- rstnick
19 May 2026 17:09 - 19 May 2026 17:14The new Reg/Rec I will try first has 6 wires.Are you currently using a 5 or 6 wire reg ? (does it have a brown ?) if 6 what is the voltage on the brown when the engine is running ?I'm also troubleshooting a charging system issue on my 1983 kz1000.
I will test power on the brown when I get around to firing her up again.
I'm waiting on a new fuse box, and it's plug gets sandwiched bewteen the two metal plates on the left side where the 6 (4 in my case) connectors sit.
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
Last edit: 19 May 2026 17:14 by rstnick.
- asphalt900
20 May 2026 00:50
Steve You always say "Ride the Piss out of it", Maybe you should change that to rode the protons out of it ha. I've plenty of used good stators..if you want one?
22 May 2026 15:21
Thanks Clay. I'll send you a PM. I plan to buy another SH775 in case this one has an internal short. Also run a new + to the battery.
22 May 2026 16:51
Here is a clean one for cheap. If you don't buy it, Steve, I will. I'll give you a day or so...
https__://www.ebay.com/itm/298295110296 (remove underlines)
