Wideband and resistance
- bry195
Re: Wideband and resistance
13 Jan 2026 04:59
yea, within the sensor there is a voltage. The signal is current and difficult to mess up.
- DOHC
- Those Doe-Hawks really go!
14 Jan 2026 06:01 - 14 Jan 2026 06:13my understanding is that the "Nernst voltage" determines the current requirement of the pump cell.
I have never looked into how a wideband works, but Wookie's comment above sounds exactly right to me based on this page: www.wbo2.com/lsu/lsuworks.htm
This diagram provides a more complete picture of the sensor and the circuit used to measure it. I also found some actual schematics of wideband reading circuits and they show the same configuration.
As I read it, the VS pin (Nernst voltage) is measured by the controller, and compared to a 450mV reference. Based on this measurement, the amount of pumping current is adjusted to try to make the VS voltage match the 450mV reference. The amount of pumping current required is measured and this current measurement is used to determine the oxygen concentration.
So it's not really fair to say that the sensor uses a true current loop, similar to something like a 4-20mA current loop industrial sensor. It's definitely more complicated than that, and it's definitely measuring the output Nernst voltage on the VS pin.
And as you said, your list is the entire proof.
- Measured Nernst voltage
- Drives pump current to null error
- Reads the required current
- Converts current → lambda
The first setup is to measure the Nernst voltage relative to the Vs/Ip wire/pin of the sensor. If there were an offset or error in the Nernst voltage measurement, that would cause the controller to send the wrong pumping current, and this incorrect pumping current measurement would be used to calculate an incorrect AFR reading.
'78 Z1-R in blue
, '78 Z1-R in black,
'78 Z1-R in pieces
My dad's '74 Z1
'00 ZRX1100
My dad's '74 Z1
'00 ZRX1100
Last edit: 14 Jan 2026 06:13 by DOHC.
The following user(s) said Thank You: Injected, Wookie58
- DOHC
14 Jan 2026 06:12Hello everyone, simple question for you all !! I have stock Coil and Ton’s wire 0ohm with 1kw NGK cap and B8es plugs .. Do my AEM AFR gauge gonna give me trouble if I dont have at least 5kw resistance? False reading?
thank you and Merry Christmas 🌲🙂
I second Wookie's advice: "You should ok, just try and ensure your wiring is as far as possible away from the HT leads/plug caps"
I also agree with the initial comment from bry195, specifically referring to the wideband sensor wires: "if you tried your hardest you probably couldn’t introduce electrical noise into the system."
Another potential (but unlikely) issue is that spark noise could upset the internal electronics of the AEM AFR gauge itself. Modern electronics (the kind that didn't exist in 1980) can be sensitive to radio interference and can be hard to shield.
So when Wookie refers to "wiring", keep all the wiring away from the HT lead/plug caps. That would include not just the wideband sensor wiring, but the power supply wires for the AFR gauge and any other modern electronics you might happen to have on the bike.
And as bry195 mentioned, twisting the wires helps to avoid noise pickup, so twist the power and ground wires together.
'78 Z1-R in blue
'78 Z1-R in pieces
My dad's '74 Z1
'00 ZRX1100
My dad's '74 Z1
'00 ZRX1100
14 Jan 2026 12:32I kind of went full overboard on mine because of the electronics and "Lin-Bus" data transfer (screened both looms where they run over the coils and HT leads)So when Wookie refers to "wiring", keep all the wiring away from the HT lead/plug caps. That would include not just the wideband sensor wiring, but the power supply wires for the AFR gauge and any other modern electronics you might happen to have on the bike.
- Injected
14 Jan 2026 14:24 - 14 Jan 2026 14:32Is that wire covering tinned copper?I kind of went full overboard on mine because of the electronics and "Lin-Bus" data transfer (screened both looms where they run over the coils and HT leads)So when Wookie refers to "wiring", keep all the wiring away from the HT lead/plug caps. That would include not just the wideband sensor wiring, but the power supply wires for the AFR gauge and any other modern electronics you might happen to have on the bike.
1978 KZ650B2 modified project
Last edit: 14 Jan 2026 14:32 by Injected. Reason: sp
- bry195
14 Jan 2026 17:26 - 14 Jan 2026 17:42
The original problem statement is whether the wideband will have a problem from noise.
My answer was no because its a current measurement not voltage.
Wookie said there is voltage and current and some guy said protect it.
I said or maybe just inferred the signal wire is the only thing that is important and current signals are very hard to mess up.
Wookies functionality understanding is mostly/maybe completely sound.
I clarified for posterity that the current is the important circuit as it relates to whether a problem is created by…
Im not really sure there was or was not a disagreement.
Im an engineer and used to working with engineers. In my experience some people misinterpret statements as attacks. its not intended that way.
But I give the benefit of the doubt to Wookie because he is super helpful and he prefers to stabilize situations. He deserves all my respect.
There is nothing wrong with being super cautious. Holy cow, Beautiful work wookie.
Last edit: 14 Jan 2026 17:42 by bry195.
15 Jan 2026 00:33It is indeedIs that wire covering tinned copper?
