Wideband and resistance
  • Maxbou92
  • Maxbou92's Avatar Topic Author
21 Dec 2025 08:07
#919957
Hello everyone, simple question for you all !! I have stock Coil and Ton’s wire 0ohm with 1kw NGK cap and B8es plugs .. Do my AEM  AFR gauge gonna give me trouble if I dont have at least 5kw resistance? False reading?
thank you and Merry Christmas 🌲🙂
Kz750e 1980
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
Re: Wideband and resistance
21 Dec 2025 09:44
#919958
You should ok, just try and ensure your wiring is as far as possible away from the HT leads/plug caps. AFR should be fine anyway as it's simply a sensitive voltmeter (the lambda sensor generates a small voltage between 0v and approx 1.5v dependent on the AFR ration) weak is a low voltage and rich a higher voltage. Any interference will show as a "flicker" rather than a false reading
  • Maxbou92
21 Dec 2025 09:47
#919959
Ok!! So it can « flicker » and show different numbers at the same time?
Kz750e 1980
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
21 Dec 2025 10:09
#919960
I suspect the speedo and tacho may read correctly but flicker, the rest should not be effected
The following user(s) said Thank You: Maxbou92
  • Maxbou92
21 Dec 2025 21:02
#919969
Is it worth it to have resistance « removal » ?
Kz750e 1980
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
21 Dec 2025 22:47
#919970
What are you referring to with AEM - ? the resistance is there primarily for reduction of radio interference
  • Maxbou92
21 Dec 2025 23:40
#919971
Aem wideband!! My spark is supposed to be « better » with 1000ohms and no resistor wires? I had resistor wires and 5000ohm cap before!!
Kz750e 1980
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
22 Dec 2025 00:48
#919973
Got it (I didn't recognise the acronym) you should be fine with the 1Kohms caps
  • bry195
  • bry195's Avatar
12 Jan 2026 06:06
#920569
if you tried your hardest you probably couldn’t introduce electrical noise into the system. The measurements come from current not voltage. The ground is not a real ground it’s a virtual ground. The wiring is twisted pair which means any noise that is picked up will be picked up by signal and ground. That cancels noise because the measurement is the difference between signal and ground. if they both rise then its canceled out.
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
12 Jan 2026 07:00 - 12 Jan 2026 07:02
#920570
if you tried your hardest you probably couldn’t introduce electrical noise into the system - There is a reason why the likes of "Motogadget" and Axel Joost" tell you to mount control units away from HT sources ? unsurpressed ignition does create interference to varying degrees.. The measurements come from current not voltage. - Wideband relies on both voltage and current - the voltage gives a measurement and the current value required to produce the required voltage reading is measured by the ECU (see below)  The ground is not a real ground it’s a virtual ground. The wiring is twisted pair which means any noise that is picked up will be picked up by signal and ground. That cancels noise because the measurement is the difference between signal and ground. if they both rise then its canceled out. I have never seen a twisted pair on a lambda sensor (shielded yes) twisted pairs are normally used for "can-bus" data transfer (to the best of my knowledge)
Last edit: 12 Jan 2026 07:02 by Wookie58.
  • bry195
  • bry195's Avatar
12 Jan 2026 16:28 - 12 Jan 2026 19:22
#920597
  • Do I get extra credit because I work for Bosch? I’m just kidding, I really dont have a deep need to be right but it would be good to know if I am wrong considering how many standalone and integrated sensors ive used. A non-wideband is a voltage outputting sensor for sure. I know this first hand from using a meter to tune bikes before wideband came out. I believe AEM (wideband) still uses the LSU 4.9 from Bosch with built in signal conditioning (built into gauge). There is an analog output (voltage) and serial for use by an aftermarket engine control unit. That analog is not shielded but its also mounted somewhere near the dash.
  • From the highlighted text
    The amount of current required to maintain a specific oxygen level indicates the air fuel ratio.”
    That sentence is the entire proof.
  • Measured Nernst voltage
  • Drives pump current to null error
  • Reads the required current
  • Converts current → lambda
  • If you connect a wideband sensor to a voltmeter:
  • You get a flat ~450 mV
  • No AFR information exists
  • The voltage is not the measurement
  • The voltage is clamped
  • The voltage contains no AFR information once regulated
  • A wideband oxygen sensor is a current-mode electrochemical transducer in which lambda is encoded in the pump cell current required to maintain a fixed Nernst cell voltage.
    and the Bosch block diagram supports it.
    I think that depending on where you look and which sensor/controller, you could find an analog signal that is scaled to AFR but the only signal that should be in proximity to the ignition system comes from the current in the controller. voltage is fixed before the conditioner. Thats why they need calibration. After the signal conditioner some controller have an analog voltage signal. If its referenced to ground and near the ignition system you should use noise mitigation techniques but the conditioner is usually at least 6 foot away from the sensor. Maybe there are more that arent twisted pair than are but I dont think its really relevant other than just discussion and half of the readers are technically lost and just trying to decide who is the idiot, LOL. Im not implying anyone is ann idiot but we both know that you would have the most social support.
    Anything that uses a virtual ground or differential measurement benefits from twisted pair and I have seen it, if its interesting maybe i can find something for you. Analog voltage speaker outputs or current driven ethernet communications (current driven like CAN) are both differential and twisted pair.  I do have a bias against “noise though”. Ive literally had at least 500 people tell me there problems must be from noise and so I have had to scope all of these problems just to put someone mind at ease and maybe 10 times noise was present and 2 times it caused a problem. You really have to do things the wrong way to get noise that is a problem. Just watch wire routing and grounds.
    I hold nothing for or against expertise or experts other than I treat them the way i like to be treated. Most people do not assume someone posting on a forum could be an expert but the content of what someone is saying should be evaluated on its own. None of what i have said is intended to be a knock on you. It’s just my perspective that may be wrong but I share what I know. Ive already conceded you are at least partially right.
Last edit: 12 Jan 2026 19:22 by bry195. Reason: it doesnt seem to be keeping the changes i made.
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
13 Jan 2026 00:58 - 13 Jan 2026 01:17
#920603
Wow !! - not looking to get into a "bun fight" with you over this, I am aware from previous posts that you are no stranger to "engine management" and was simply pointing out that my understanding is that the "Nernst voltage" determines the current requirement of the pump cell. So am I wrong that within the sensor it is the Nernst cell that measures oxygen content and which determines required "pump current" to generate the correct AFR value?
Last edit: 13 Jan 2026 01:17 by Wookie58.
The following user(s) said Thank You: Injected
