1981 GPZ1100 Ignition won't turn.
- H1Vindicator
Re: 1981 GPZ1100 Ignition won't turn.
07 Aug 2025 08:06
maybe. maybe not. its' a possible solution if need be. the op can assess his situation.
- clagrow68
07 Aug 2025 20:01
All WAS going well until I looked down to pickup the barrel to reinstall it and the locking wafer and spring were gone! I only walked in a straight line about 20ft with it and can't find it anywhere. Looks like the Vulcan 750 is basically the same with a different connector, may have to go that route.
1978 Kawasaki KZ1000
1981 Kawasaki GPZ1100
08 Aug 2025 00:58Well that "SUCKS" (you know once you have found an alternative the missing part will turn up ) looking at the pics since your problem is mechanical you may be able to swop the switch onto the Vulcan assembly so you don't have to mess with the connectors ?All WAS going well until I looked down to pickup the barrel to reinstall it and the locking wafer and spring were gone! I only walked in a straight line about 20ft with it and can't find it anywhere. Looks like the Vulcan 750 is basically the same with a different connector, may have to go that route.
- clagrow68
08 Aug 2025 09:41
That is my exact plan!
- F64
- 81-KZ440D2
08 Aug 2025 10:05 - 08 Aug 2025 10:28
How many wafers are in that lock?
You may be able to use that lock without that one wafer.
You'll still have the other wafers to secure the lock.
Of course it may be slightly easier to brute force the lock with one less wafer to shear
81-KZ440-D2.
LIC, NY
LIC, NY
Last edit: 08 Aug 2025 10:28 by F64.
08 Aug 2025 12:13 - 08 Aug 2025 12:14I believe the missing wafer is the one that secures the barrel in the housing (it's the only one the key doesn't hold in)How many wafers are in that lock?
Last edit: 08 Aug 2025 12:14 by Wookie58.
- clagrow68
13 Aug 2025 07:34 - 13 Aug 2025 07:35
Yeah, the wafer that is missing is the one that holds the cylinder in the barrel. BUT, the new "Vulcan switch" is due to arrive today!
Last edit: 13 Aug 2025 07:35 by clagrow68.
- clagrow68
14 Aug 2025 09:06 - 14 Aug 2025 09:17
Got it installed last night. Since the issue was mechanical, I simply had to swap the electrical part from the old to the new. It works. The only issue is that the key position on the new one doesn't line up with the marks on the plastic bezel, but i can live with that.
Last edit: 14 Aug 2025 09:17 by clagrow68.
