Checking the charging system
- RetroRipper
04 Jun 2025 16:42
How do I check the charging system on my 1976 Kawasaki kz400-D. I accidentally reversed the leads from a jump box and fried a few wires but when I hook up the bike with jumper cables to a car, with a battery in it, it will run just fine. I want to know how to check the R/R with a meter and know the ohms etc and how to properly check the system. TIA
- hugo
- '92 Zephyr 750
Re: Checking the charging system
04 Jun 2025 17:34 - 04 Jun 2025 17:37
Just fried a few wires???? ......That was all???...basically, at idle it should be a little about 13 VDC, and if reved, it should go above 14 VDC. It is really a 14 VDC system.
Last edit: 04 Jun 2025 17:37 by hugo.
04 Jun 2025 17:56
I bet the factory service manual has a pretty good testing procedure.
www.kzrider.com/filebase-alias?task=down...id=1231&catid=11&m=0
05 Jun 2025 00:08
Older vehicles with few electronics tend to brush off a bit of "reverse polarity" action fairly well. More modern ones would need new control units for just about everything
- RetroRipper
05 Jun 2025 10:12
Yeah just a few. It burned the wire coating but it stills runs very well. I just don’t think it’s charging.
- gd4now
- Denco where did you go?
05 Jun 2025 10:36
As suggested there are tests in the service manual that I would suggest you read and run. You may find info in this post of interest as well.
kzrider.com/forum/2-engine/621566-650-75...compatability#911518
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
