Front Master Cylinder Q?
  • saltroni
  • saltroni's Avatar Topic Author
07 Feb 2025 08:38 - 07 Feb 2025 08:41
#908728
My freshly rebuilt front master cylinder wont pump... Question is, should both holes in the bottom of the reserve be open? Only the one closest to the brake lever is open, the other does not go through to the piston. On the inside of the cylinder, I cant see any sign that it ever went all the way through.  But she no pumpy!
Sorry for putting it in the wrong forum......
Last edit: 07 Feb 2025 08:41 by saltroni.
  • TexasKZ
  • TexasKZ's Avatar
Re: Front Master Cylinder Q?
07 Feb 2025 09:21
#908732
Yes, it needs to be open. It is a really tiny hole.
The following user(s) said Thank You: saltroni
  • Nessism
  • Nessism's Avatar
  • Away
07 Feb 2025 10:38
#908736
Yes, tiny.
When you pull the hand lever, with the lid off, a stream of fluid will shoot out of that hole, so consider this your warning!  The regular wrenchers are no doubt laughing after reading that, since many of us have managed to squirt ourselves, and the bike, learning (the hard way) this nugget of wisdom.
The following user(s) said Thank You: sf4t7, saltroni
  • saltroni
07 Feb 2025 12:39 - 07 Feb 2025 12:52
#908739
Thanks Fellas, I just used a Torch tio cleaner to clean the hole. It measured out to be .0017" or .4318mm.
Last edit: 07 Feb 2025 12:52 by saltroni.
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
07 Feb 2025 12:46
#908741
Yes, tiny.
Also don't forget brake fluid is an incredibly effective "paint stripper" especially when it gets were you don't want it (another lesson learned the hard way many years ago !!!!!)
  • saltroni
07 Feb 2025 14:43 - 07 Feb 2025 14:45
#908747
Next question, do the piston cups go in the same direction or face each other? I ask because there is no squirt out of the freshly opened "little hole".
Thanks you guys are Awesome!
Last edit: 07 Feb 2025 14:45 by saltroni.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
07 Feb 2025 15:56 - 07 Feb 2025 15:57
#908748
The piston rubber gaskets should face the same direction.
Small OD to the leveler, big OD to the brake line/banjo bolt.
See animation made by Lou D, R.I.P......
Last edit: 07 Feb 2025 15:57 by Scirocco.
The following user(s) said Thank You: Nessism, MFP-Joe, sf4t7, kimchella
  • saltroni
07 Feb 2025 16:12
#908750
Scirocco, Thanks. Thats the way they are. For some reason the master isnt building pressure. I got this master from ebay for my barn find because it was missiing.  There is some corrosian that I tried to hone out , I must not have done a good enough job. I will give it another shot tomorrow.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
07 Feb 2025 16:24
#908751
Sometimes bleeding a brake sytem could be a pain in the a**.
Reverse bleeding with a syringe or hanging up the caliper in the air over the MC level is the only option.
  • Nessism
  • Nessism's Avatar
  • Away
07 Feb 2025 17:36
#908757
If the bore is corroded, the master is junk.  Get a new one.
5/8" bore (16mm) for a dual disc bike, or 14mm bore master for a single disc bike.  I used a rectangular reservoir EX650 master for my bike and it works great.
  • asphalt900
  • asphalt900's Avatar
08 Feb 2025 01:08
#908766
You may not of noticed but some of those Tokiko masters had a metal sleeved bore, a real propensity to rust/rot out. I've tossed soo many of those over the years could fill a dumpster. If you somehow ended-up with a good metal bore one, crack the line banjo at the master after pumping lever and holding it. Repeat several times, you'll feel it priming. Like Wookie said, keep some rags underneath it to capture the sweet sweet fluid. What you're doing is filling both chambers of master and starting the bleeding process.
  • asphalt900
08 Feb 2025 01:15
#908768
Forgot to mention. If this bike is a rescue and has been sitting a long time, the lines/splitter could be clogged-up too. This will hamper any bleeding. Ya might pull the pull the caliper banjos off and verify fluid presence. This is if you don't have any brake vacuum equipment.
