KZ650 converted to electronic fault
  • hardrockminer
  • hardrockminer's Avatar
Re: KZ650 converted to electronic fault
24 Dec 2024 04:15
#907117
I will still check my 650 engines and get back to you.
One difference with the bigger engines is that yours has only one spring.  My Z1 advancers have two.
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
24 Dec 2024 05:33
#907118
As I understand it here are the part numbers for the advance unit on the 650s
21148-011 (points)
KZ650-B1 (1977)
KZ650-B2 (1978)
KZ650-B2A (1978)
KZ650-B3 (1979)
KZ650-B4 (1980)
KZ650-C1 (1977)
KZ650-C2 (1978)
KZ650-C3 (1979)
KZ650-C4 (1980)
KZ650-D1 (SR) (1978)
KZ650-D1A (SR) (1978)
KZ650-D2 (SR) (1979)
KZ650-E1 (LTD) (1980)
KZ650-F1 (1980)
21148-1022 (electronic)
KZ650-H1 (CSR) (1981)
KZ650-H2 (CSR) (1982)
KZ650-H3 (CSR) (1983)
KZ650-F2 (1981)
KZ650-F3 (1982)
KZ650-F4 (1983)
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
  • hardrockminer
24 Dec 2024 11:53 - 24 Dec 2024 12:04
#907134
I was able to check one in my parts bins, but the other one is on an engine in a 650 stored up against a wall where it's difficult to access.  I took a photo of the one I found.  It has no 1016 code on it and it has two springs.  I think someone may have switched advance units on your bike at some point.  (Or is it for an OEM electronic ignition?). I can definitely say mine came from a 650 engine, but it may not have been original to the bike...I just don't know.  The engines are 77 and 78.
Edited to add that the manual I have for a 650 says the advance should be 10 deg BTDC at 1,600 and 35 deg BTDC at 3,200 rpm.  Neither of my engines are electronic ignition.
Last edit: 24 Dec 2024 12:04 by hardrockminer.
  • MauserXR
  • MauserXR's Avatar Topic Author
24 Dec 2024 12:29 - 24 Dec 2024 12:32
#907135
Mine has 2 springs on it
KZ650 ~ XR650R ~ KH400 ~ RT2-360
Last edit: 24 Dec 2024 12:32 by MauserXR.
  • MauserXR
24 Dec 2024 12:35
#907136
That part number matches up with the one I purchased and fitted (1016) see attached image.
Any thoughts about the resister in the plug cap ?, mine are NGK 5ohm resister type ? should I be using the non resister type ?
Happy Christmas when it gets here.
  • hardrockminer
24 Dec 2024 14:21
#907137
According to Partzilla the one you bought (1016) is for a KZ550.  GD4Now has pointed out that the correct number for a KZ650 is 1022.  I checked Partzilla and he is correct.
  • MauserXR
24 Dec 2024 14:32
#907138
Any idea what the difference is ?, as mentioned others on the forum have fitted the 1016 on their KZ650's ?
  • hardrockminer
24 Dec 2024 16:33
#907140
I don't know what the difference is.  You might try contacting someone who has used the 1016 advancer to see how their bike runs.
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
25 Dec 2024 03:32 - 25 Dec 2024 03:34
#907147
Just had a quick look on CMNSL - the pick-ups look to be generic across 650/750 models but the 1022 advancer appears to be 650 specific ?? Have you tried using a strobe to see what is happening when you pick up the revs ?
Last edit: 25 Dec 2024 03:34 by Wookie58.
  • gd4now
  • gd4now's Avatar
25 Dec 2024 07:56 - 25 Dec 2024 16:47
#907153
I may of taken this topic off its rails with the part number info, that was not my intention. The advancer you installed may work fine with your machine, I certainly do not know that it will not. I am still interested in what igniter you are using? Is it for a 550 650 1000 or some other bike/model?
From some of the manuals I have access to the 650 stock points systems indicate the following
from 10 degrees BTDC @ 1600 rmps to 35 degrees BTDC @ 3200 rpm
650 electronic system indicate the following
10 degrees before BTDC @ 1000 rpms to 35 degrees BTDC @ 3200 rpm
the 550 manual indicates
10 degrees before BTDC @ 1050 rpm to 35 degrees BTDC @ 3200 rpm
1977 KZ650 B1
Last edit: 25 Dec 2024 16:47 by gd4now.
  • MauserXR
26 Dec 2024 06:43
#907162
Hi Wookie, I have found a 1022 in the UK but guy wants £100 which is a lot if it don't cure the problem. Bikes driving me crazy at the moment I have gone from a slight misfire at tick-over when blipping the throttle to a bike which won't rev properly lol. I have a strobe gun but never 100% sure how your supposed to see the marks through the tiny hole  etc.
As it stands today, she started OK but cylinder 1 was cold ?, checked float bowl which had fuel, checked for spark which was good....several minutes later the cylinder starts up but she still doesn't run well at 0-1/4 throttle once past all seems good but cannot road test as weather is poor.
New 3 ohm coils coming tomorrow/Saturday which the guy I purchased the pickup & ignitior said could be the problem? he says he's had problems in the past using 4 ohm coils with electronic ignition modules.
I can temporary wire these coils in and weather permitting test ASAP
  • MauserXR
26 Dec 2024 06:47
#907163
Sorry I tried posting the link to eBay but it failed, the IC was from a KZ650 D picture attached.
I would presume this would be perfect for my KZ650 B ?
Cheers Simon
