Starter Motor KZ750B
- GR77KZ750
22 Aug 2024 10:58
Hi All,
I have an amazing 1977 KZ750 that I can't ride cuz the starter died.
Any chance one of you out there has a motor they might want to part with?
Please shoot me a message.
Thank you!
Thank you!
- GR77KZ750
Re: Starter Motor KZ750B
22 Aug 2024 11:10
Are you sure the fault is the starter itself ?
- GR77KZ750
01 Sep 2024 11:57
yea, my mechanic says it runs fine but the motor is shot. Can't find a starter motor anywhere...
Do you have any other ideas?
01 Sep 2024 12:47
Here are some possibilities
www.motorcityreman.com/620-079.html
www.obbstartersandalternators.com/18633n...e1500-na-p-2173.html
A rebuild kit. www.obbstartersandalternators.com/6991-1...3n-18633-p-5628.html
01 Sep 2024 13:08
You need to determine what is wrong with it before you decide repair/replace “shot” isn’t really a diagnosis!! If it was an auto parts store item for a regular car you would simply replace (after accurate diag) but a 50 year old import motorcycle is a different proposition
- H1Vindicator
02 Sep 2024 06:21
make certain the battery is good. do a load test.
- gd4now
- Denco where did you go?
04 Sep 2024 09:03
As others have indicated you should see if the issue is the starter or the battery. You can make a high current shunt for testing. I have posted this in the past and will point you to one of those posts instead of adding the info once again. Check out this post
kzrider.com/forum/4-electrical/619426-kz440-starter-draw#890206
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
