- Thank you received: 2059
gpz1100b1 idle switch
10 Jul 2024 16:17 #901990
by Scirocco
Replied by Scirocco on topic gpz1100b1 idle switch
Mail received!
The german DHL shipping costs for the UK and US region are more socially acceptable as the US insane shipping costs !!!
11 Jul 2024 03:47 #901999
by Scirocco
Your parts has been payed and on the way to my adress.
17 Jul 2024 13:14 #902275
by Scirocco
The following user(s) said Thank You: ajh
- ajh
- Thank you received: 7
17 Jul 2024 14:15 #902278
by ajh
A
1981 GPZ1100b1, 1980 CB750Fa, 1981 RD350LC, 1980 DT175mx, 1982 GS550ez
Replied by ajh on topic gpz1100b1 idle switch
Great news, they look really good. Thanks so much for arranging.Adrian, your parts arrived today!
A
17 Jul 2024 15:01 - 17 Jul 2024 15:08 #902280
by Scirocco
You have to pay some extra money for the cleanig of my living room, tiny little paper chips everywhere, arrrrgh
All parts will get some light cleaning, lubrication and the throtte body a static sync before shipping to make some things easier for you ......
Last edit: 17 Jul 2024 15:08 by Scirocco.
- ajh
18 Jul 2024 04:30 #902294
by ajh
Thanks Michael, thats very good of you, I hope I can repay the favour sometime. And I just pray the switches are working! (cant find the fingers crossed emoj)
And make sure you put all the paper chips in the parcel so I can spread them all over my house to make you feel better!
A
A
18 Jul 2024 13:20 - 18 Jul 2024 13:23 #902313
by Scirocco
I had cleand the throttle body as good as possible, lubed the shafts and static sync the butterflys.
Will shipping package tomorrow, paper chips are dumped in the paper recycle bin.
You will get bubble wrap instead....
Last edit: 18 Jul 2024 13:23 by Scirocco.
19 Jul 2024 01:54 #902335
by Scirocco
Btw, the idle switch did work and the packege weight isn´t heavier than 5 Kg.
So you don´t need send extra money for the shipping!
- ajh
19 Jul 2024 09:58 - 19 Jul 2024 09:59 #902350
by ajh
Once again thank you so much for everything you have done to help me get these parts.Btw, the idle switch did work and the packege weight isn´t heavier than 5 Kg.
Last edit: 19 Jul 2024 09:59 by ajh.
19 Jul 2024 14:21 #902357
by Scirocco
No problem, you can donor some money to the KZR forum community for the "plan A steal deal" parts and labor service..........
20 Jul 2024 12:06 #902392
by Scirocco
Adrian, e-mail send ---> DHL tracking#
- ajh
27 Jul 2024 09:25 - 27 Jul 2024 09:36 #902597
by ajh
Package arrived. Some very good looking clean parts, throttle bodies look like new! (See pics)
Thank you very much for all your help and time on this
The bike is now running pretty good, even with a faulty throttle switch. I havent fitted the new one yet but the new idle switch is fitted and working
Having now ridden it, I think my injectors are leaking so the injectors you sent are going to be useful!. It wouldnt start from hot a few minutes after a long run and I found the plugs were wet and fouled. Turning the gas tap off and letting the FI run dry seems to prevent this happening. I can clean and test the set of injectors and swap them in when I do the Throttle switch.
BTW, so far Ive tried 3 throttle switches and according to the LEDs, none of them worked 100%. My current switch now works on idle with the new idle switch (Green LED), another Ive got works only on throttle open (Red LED) and the other doesnt work at all (No LEDs). Hopefully Ill get lucky with the one you sent (Pita, I dont think its possible to open up and repair these things and there doesnt seem to be alternatives as they seem to be very proprietory to Kawasaki - kzrider.com/forum/4-electrical/618169-kawasaki-gpz-1100b1 )
I'll keep you informed on progress, once again thanks!
Hi MichaelAdrian, e-mail send ---> DHL tracking#
Last edit: 27 Jul 2024 09:36 by ajh.
The following user(s) said Thank You: Scirocco
