82 kz1100 speedometer and odometer quit working and tach has been jumpy
- Gdailey2112
- 82 KZ1100D1
Re: 82 kz1100 speedometer and odometer quit working and tach has been jumpy
19 Apr 2023 16:58
daveo - thank you so much, bro! ...80 gritted the eye conn and mating surfaces for yel/blk ground on coil mount and solved my jumpy tach
wookie - yes i read how to check by spinning front wheel to gain volt reading from odom to speedo and that seems to check out good
1982 KZ1100D1
- Gdailey2112
- 82 KZ1100D1
19 Apr 2023 17:28
wookie - speed sensor is sending pulse starting out at just below 1 volt and voltage raises fine when wheel is spun. i'm stumped unless odometer isn't sending pulse to to speedometer
1982 KZ1100D1
20 Apr 2023 03:54 - 20 Apr 2023 03:57
The below should give us a starting point, let me know what you get for each of the 5 test steps
Is your bike fitted with "self cancelling" turn signals, if yes "do they work"?
Last edit: 20 Apr 2023 03:57 by Wookie58.
The following user(s) said Thank You: Mikaw, Gdailey2112
- Gdailey2112
- 82 KZ1100D1
20 Apr 2023 18:17 - 20 Apr 2023 18:18
wookie - thank you for your help and expertise
will run those tests in morning thanks again
yes it has self cancelling signals that don't self cancel
1982 KZ1100D1
Last edit: 20 Apr 2023 18:18 by Gdailey2112.
- Gdailey2112
- 82 KZ1100D1
20 Apr 2023 20:22
i guess i've never known of any easy way to get these old 6 pin connectors in headlamp apart, any tips?
few of the conn's seemed to be like welded as one on one or two sides, pulling does not suffice
1982 KZ1100D1
20 Apr 2023 23:39Don't forget these tests are done from the back of the plug with it connectedi guess i've never known of any easy way to get these old 6 pin connectors in headlamp apart, any tips?
few of the conn's seemed to be like welded as one on one or two sides, pulling does nothing
- Gdailey2112
- 82 KZ1100D1
21 Apr 2023 08:18 - 21 Apr 2023 08:29
anyone know of a better way to un-weld the original connectors inside headlamp.
the one i'm pulling on doesn't allow much room on one side to pull from
i do understand the tests to be done connected but still wanna get the two apart
1982 KZ1100D1
Last edit: 21 Apr 2023 08:29 by Gdailey2112.
21 Apr 2023 09:17You could try soaking them in WD40 (it's corrosion that's holding them) JUST MAKE SURE YOU BLOW OUT THE EXCESS BEFORE PUTTING POWER THROUGH ITanyone know of a better way to un-weld the original connectors inside headlamp.
The following user(s) said Thank You: Gdailey2112
- Gdailey2112
- 82 KZ1100D1
27 Apr 2023 19:30
Hey wookie! Sorry bro, I know you'd spent a bit of time helping with this, however, I didn't even get a chance to do any testing yet. My other half seems to always somehow gets in the way with her priorities when its sunny, 70 deg and I'm fiending to go riding LOL
1982 KZ1100D1
27 Apr 2023 23:35
No worries buddy, happy to help.
- Gdailey2112
- 82 KZ1100D1
28 Apr 2023 12:10
Appreciate your understanding and all the help you've given. Wookie, you a very valuable asset to this site. Your intellect, knowledge, and experience on electrical is right up there with the best! Thanx
1982 KZ1100D1
- Gdailey2112
- 82 KZ1100D1
29 Apr 2023 16:19
The jumpy tach has been solved, the ground blk/yel from 6 pin connector under side cover wasn't connected to anything.
1982 KZ1100D1
