82 kz1100 speedometer and odometer quit working and tach has been jumpy
  • Gdailey2112
  • Gdailey2112's Avatar Topic Author
  • 82 KZ1100D1
16 Apr 2023 14:24
#883267
so the speedometer is the electronic pulse type
recently quit working and thought it was the speed sensor however not the case
my fsm tells me to check the 3-pin and 6-pin connectors in headlamp case
these connectors are very adhered and stuck together, anyone have any tips on how to get 'em apart?
i did manage to check for battery voltage at the 3-pin speedo sensor connector - wht from male side and blk/yell from female side
with key on - no voltage
which wire in loom under tank feeds power to the odom, speedo, and tach? from what i see it's either orange or brown but not sure
also, noticed the orange odometer lead has no voltage either.
are these items related to the 10 amp horn fuse?
any ideas or thoughts, please chime in.
much thanx
1982 KZ1100D1
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
Re: 82 kz1100 speedometer and odometer quit working and tach has been jumpy
16 Apr 2023 18:29
#883286
Twenty-three years owning my 1100 have taught me to plow into problems and take chances.  If something breaks, then oh well...there's ebay.
Thing is, these bikes are tough.  They were made in Japan, not China.
Thank God.  Go for it!
1982 KZ1100-A2/1170cc sleeper 😀
  • Gdailey2112
  • 82 KZ1100D1
17 Apr 2023 10:53
#883347
so very true daveo
well now i have voltage at the 3-pin speedo sensor and it seems my odometer is at least rolling numbers same with trip meter, however the orange lead from odometer shows no volts
and from what i assume, is that the orange lead from OD then powers the speedo? i dunno but that's what it looks like on the diagram
1982 KZ1100D1
  • Gdailey2112
  • 82 KZ1100D1
17 Apr 2023 10:58
#883350
wookie wookie where are you lol
1982 KZ1100D1
  • howardhb
  • howardhb's Avatar
  • God, I trust
17 Apr 2023 11:01
#883353
Wooookeeeeeee
'81 GPz 550 D1
'82 Yamaha YB100 Fizzie
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
  • Moderator
17 Apr 2023 11:04
#883354
Will try and look at a wiring diagram later or tomorrow
  • Gdailey2112
  • 82 KZ1100D1
17 Apr 2023 17:01
#883371
thank you wookie!
1982 KZ1100D1
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
17 Apr 2023 17:54
#883375
I seem to recall a poor yellow/black ground wire connection behind a left-side ignition coil mount bolt was causing a minor tach-needle fluctuation some dozen years or so ago.
A wire brushing took care of that.
The following user(s) said Thank You: Gdailey2112
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
  • Moderator
18 Apr 2023 01:46 - 18 Apr 2023 02:54
#883387
Can you clarify which model you have, your previous posts refer to a 82 KZ1100 and a 82 GPZ1100 is it a KZ1100A? or a KZ1100 B1/B2 ? Vin number would be useful. Also can you post a picture of which instruments you have ?
Also ref the "jumpy" tach, I see you have an old post on this issue - was it resolved at that time or has it been an on-going issue ?
Last edit: 18 Apr 2023 02:54 by Wookie58.
  • Gdailey2112
  • 82 KZ1100D1
19 Apr 2023 12:33
#883446
yes i thought it was a gpz but the further i looked into it seems it's a d1 model, or 1100d1 specter
daveo - i will certainly try that, thanx
1982 KZ1100D1
  • Gdailey2112
  • 82 KZ1100D1
19 Apr 2023 12:39
#883447
does the orange wire feed signal/pulse?
1982 KZ1100D1
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
  • Moderator
19 Apr 2023 12:57
#883451
The orange is the speed signal, now I know which diagram to look at I will put something together for you (didn't want to send you down a rabbit hole with bad info  )
