Rebuilding wiring harness (electrical tape)
Re: Rebuilding wiring harness (electrical tape)
21 Jan 2023 14:05Is that R/R a SH775? Hope so anyway...
- Feanor_twh
21 Jan 2023 17:07 - 21 Jan 2023 17:08
In my experience, self-vulcanizing rubber tape apparently looks good but does not resist mechanically as PVC or Vinyl do. I rebuilt part of the wiring with this and it looks very good, but some time later it was beaten and ruined. The problem with PVC/Vinyl is the adhesive, we'll see if this 33+ works better on that.
(1976) Kawasaki KZ400-D3. All original, but: electronic reg/rec (Oregon Motorcycle Parts), new handlebar controls (w/ PASS/HORN/lights switch, LED dash lights (superbrightleds.com), Dynatek coil (3ohm), MAC mufflers, HEL brake hoses, rubber fork boots, 4.00 rear tyre (Dunlop K70), chromed chainguard
Last edit: 21 Jan 2023 17:08 by Feanor_twh.
- blipco
- 2002 KZ1000P
22 Jan 2023 07:22In my experience, self-vulcanizing rubber tape apparently looks good but does not resist mechanically as PVC or Vinyl do. I rebuilt part of the wiring with this and it looks very good, but some time later it was beaten and ruined. The problem with PVC/Vinyl is the adhesive, we'll see if this 33+ works better on that.
>>>> Self vulcanizing tape is always covered with electrical tape afterwards.
Make sure your wires (and hands) are free from grease and dirt before applying the tape, otherwise it’ll unwrap. And be careful not to stretch it too much or too little when wrapping.
Too much pull and it’ll pull itself loose at the ends.
Too little pull and it will unravel.
And have patience and preferably a warm area to apply it.
