Instrument lights
  • Michi
  • Michi's Avatar Topic Author
Instrument lights
19 Oct 2022 15:06
#875734
Hi, my KZ440 is in bits but I decided against simply reassembling it, and want to fabricate a few custom parts. One relatively safe area to consider is the instruments panel, I was thinking.
Does anyone know the wattage of the incandescent bulbs used for the oil, signal and neutral idiot lights? Think I wanna replace 'em with a smaller (also incandescent) set, in a steel housing. Just because. lol
Thanks
KZ440A LTD (1980)
  • hardrockminer
  • hardrockminer's Avatar
Re: Instrument lights
19 Oct 2022 17:24
#875735
I think they are 3.5 watts, but they should have it marked on the bulbs.
The following user(s) said Thank You: Michi
  • martin_csr
  • martin_csr's Avatar
20 Oct 2022 07:28 - 20 Oct 2022 07:28
#875756
It's been a while, but for the speedo & tach I installed heavy duty Eiko bulbs from the auto parts store (#1891).
The 1891 bulbs are longer than the stock bulbs but fit fine & also fit in the center cluster.
Alternatively, LEDs should be readily available. some searches here on KZR should help.
Last edit: 20 Oct 2022 07:28 by martin_csr.
  • blipco
  • blipco's Avatar
  • 2002 KZ1000P
20 Oct 2022 09:45
#875766
There may be two different wattages in the cluster. From memory the ones that illuminate the dials are 5 watts. The dummy lights get less wattage. 3.5 sounds right.
As for LED's.. The contact points on the base are not the same as the incandescent lamps and while LED's can give you nice color options, especially a green LED, but by my experience, they will work for a short while but after a couple of months you’re going to have a flashing disco scene going in front of your eyes. Not noticeable in daylight but at night it drives you crazy. I would never use them on a dummy light fearing a bad connection when you need it most.
I’ll be changing back to incandescent lamps unless someone can recommend an LED lamp with improved contacts.
  • Michi
20 Oct 2022 11:53
#875774
I agree 100%. There are some small 5w incandi lights and sockets on Ebay, and I think I'll go for those.
Electrics just aren't the fun part of bikes. LEDs can work but they can also fail and be a headache unless done properly. I know a motorcycle mechanic who's well up to speed on electrics, and he could do something like. But messing around with metal is more fun. Plus, normal bulbs work and there's nothing wrong with them. A good LED headlight might be a worthwhile upgrade though.
KZ440A LTD (1980)
  • blipco
  • blipco's Avatar
  • 2002 KZ1000P
20 Oct 2022 12:20
#875778
Michi, I used green LED's to illuminate the tach and speedo numbers and the green numbers and lines popped right out beautifully. I was well pleased. Then the disco started.
Beware which LED headlight you use. Some flicker at low rpm then burn out. It happened to my brother. The second one he bought didn’t flicker. They both threw much more light than the incandescent and were more visible to oncoming drivers but he just installed it so no telling how long it’ll last.
  • TexasKZ
  • TexasKZ's Avatar
20 Oct 2022 14:57
#875790
I don’t know exactly which model you have, but it looks like all but the high beam indicator are 3.4 watt. The high beam indicator is listed as 1.7 on the model I looked at.
www.kzrider.com/modules/ServiceManuals/7...chablefullmanual.pdf
  • Feanor_twh
  • Feanor_twh's Avatar
25 Oct 2022 15:17 - 25 Oct 2022 15:18
#876008
Check this post, I put a post at the bottom about the result of upgrading to LED lights. On your KZ440 the dash panel should be similar.
kzrider.com/forum/4-electrical/494986-le...ghts?start=12#865552
(1976) Kawasaki KZ400-D3. All original, but: electronic reg/rec (Oregon Motorcycle Parts), new handlebar controls (w/ PASS/HORN/lights switch, LED dash lights (superbrightleds.com), Dynatek coil (3ohm), MAC mufflers, HEL brake hoses, rubber fork boots, 4.00 rear tyre (Dunlop K70), chromed chainguard
Last edit: 25 Oct 2022 15:18 by Feanor_twh.
