Custom wiring pics
  • Bdog
  • Bdog's Avatar Topic Author
  • Sweep the leg johnny!!!
Custom wiring pics
04 Oct 2022 09:39
#875003
Hey guys I know some of you have wired your own bike, I would like to see how you've done it for a little motivation this winter.
Brandon
kzrider.com/forum/11-projects/338400-a-little-bit-of-an-upgrade
'77 KZ650-C1 -- build
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
ContiMotion tires (120/60-17&170/60-17)
  • Irish Yobbo
  • Irish Yobbo's Avatar
Re: Custom wiring pics
04 Oct 2022 20:29
#875065
I haven't done this, but to help your question - what exactly are you after? Are you intending to re-make the stock wiring loom with new wires/components, create a new loom to work with modifications the bike has, or are you after a minimalist loom (run the engine and basic functions with all unnecessary features removed). All have been done before.
1981 KZ750 LTD
  • kzstreetfighter71
  • kzstreetfighter71's Avatar
  • Atlantic West Coast
05 Oct 2022 01:09
#875070
If you are doing  your own loom from scratch then first pick up a Motogadget m.unit it will make that can be a pain in the ass fairly simple. Calum is doing this right now on his thread below on his Z1000 build, its 100% worth a look if this is what you want to be doing.
www.kzrider.com/forum/11-projects/614517...0-restomod?start=492
  • martin_csr
  • martin_csr's Avatar
07 Oct 2022 05:02 - 07 Oct 2022 05:03
#875200
Search KZR for bare bones for mattylight by loudhvx >> the topic has a bunch of simplified wiring diagrams.
Some of the diagrams may be missing but AFAIK most of them are still available.
Last edit: 07 Oct 2022 05:03 by martin_csr.
The following user(s) said Thank You: Bdog
