1980 Kz440 ignition system
  • FreshMark
  • FreshMark's Avatar Topic Author
Re: 1980 Kz440 ignition system
02 Sep 2022 17:17
#873267
So to use those individual pod type air filters instead of the stock airbox, I would need to rejet the carbs?
  • Cfoux85
  • Cfoux85's Avatar
  • 1982 Kawasaki kz 750e
03 Sep 2022 12:41
#873288
You can boil some water and soak the boots in the hot water. That'll make the boots more easier to put on
  • Nebr_Rex
  • Nebr_Rex's Avatar
03 Sep 2022 18:02
#873304
Yes , get the jet kit .
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • 82KZ305Belt
  • 82KZ305Belt's Avatar
04 Sep 2022 06:44
#873319
440 airboxes are not hard to find on ebay or bike yards.
81 KZ650 CSR
77 KZ650B (not in my paws yet)
82 KZ305 CSR
  • FreshMark
04 Sep 2022 14:04
#873345
I was messing around with the bike today, and spraying starting fluid in the lower intake box (I don’t have the upper box w filter element). I probably sprayed too much but while cranking, there was a pretty big fireball from the airbox. What would cause this kind of backfire?
  • Nebr_Rex
  • Nebr_Rex's Avatar
04 Sep 2022 18:09
#873354
Either getting to the spark plug.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
  • FreshMark
06 Sep 2022 08:53
#873451
Is this something that I should look into more?  Does this mean the spark timing is off?
