1980 Kz440 ignition system
- FreshMark
29 Aug 2022 07:25
Hello,
I have a 1980 Kz440A LTD that I am trying to get running. The engine cranks well, seems to have good compression and has been getting spark (though not super strong). What are some troubleshooting things I should try to get the bike running? I realized the timing cam was off by 180 degrees so I reversed that so that the points open at TDC. Should I readjust the timing?
Thanks
Thanks
- F64
- 81-KZ440D2
Re: 1980 Kz440 ignition system
29 Aug 2022 09:18
have you sprayed starting fluid into the carbs?
81-KZ440-D2.
LIC, NY
LIC, NY
- FreshMark
29 Aug 2022 09:21
I sprayed starting fluid into the air box. I was going to take the air box out this afternoon to gain access to the carb intake. How sensitive is the ignition timing? If it’s off by a few degrees is that enough t prevent it from starting?
29 Aug 2022 09:58 - 29 Aug 2022 10:00What do you mean by "timing cam" if the camshaft timing was 180 degree's out you would not have good compression and there would likely be some "mechanical lovemaking"Hello,
Thanks
Last edit: 29 Aug 2022 10:00 by Wookie58.
- FreshMark
29 Aug 2022 10:20
I mean the cam on the timing advance, sorry. The timing advance I had was stamped KZ400 and I am able to remove the cam from the lever arms. I wasn’t sure if the 400 and 440 share a timing advance or if it was replaced. Now the points are opening around when the engine reaches the F mark
- F64
- 81-KZ440D2
29 Aug 2022 12:27
so your engine does not fire with starting fluid?
81-KZ440-D2.
LIC, NY
LIC, NY
- Nebr_Rex
29 Aug 2022 20:16
What color is the arc on the spark plug? Blueish white is what you want.
How many volts are getting to the coil?
Points or electronic?
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- FreshMark
31 Aug 2022 15:36
Just installed new points and condenser and reset the timing and that seemed to do the trick. The spark seemed a brighter whitish blue, and the engine did start a bit on starting fluid. I don’t have gas rn to try for real, but I think I fixed the ignition issues. Any advice on remounting the boots of the air box onto the carbs?
31 Aug 2022 16:24I always use a smear of washing up liquid on tight rubbers, the lube helps them slide on but it dries out so won't make them slide off again at. A later date like other lubes willJust installed new points and condenser and reset the timing and that seemed to do the trick. The spark seemed a brighter whitish blue, and the engine did start a bit on starting fluid. I don’t have gas rn to try for real, but I think I fixed the ignition issues. Any advice on remounting the boots of the air box onto the carbs?
- Nerdy
31 Aug 2022 17:35I always use a smear of washing up liquid on tight rubbers, the lube helps them slide on but it dries out so won't make them slide off again at. A later date like other lubes will
For the US-ians, washing up (WU) liquid is dish soap.
I used that technique in the 1980s to install new rubber handgrips - then I discovered the compressor method.
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
The following user(s) said Thank You: slayer61, Wookie58
- FreshMark
02 Sep 2022 04:18
This doesn’t really have to do with electrical stuff, but I just realized I’m missing the top piece of my airbox which actually would house the filter. I believe it would cover the battery when it is installed? I don’t have anything like that. How well does this engine respond to the individual pod style filters that clamp right onto the carbs?
Thanks
Thanks
- Nebr_Rex
02 Sep 2022 12:55
CV carbs are more of a pain to jet correctly than slide carbs.
You will need to get a DynoJet kit for a KZ750h[LTD].
This is the best way because you need the jet needle that comes with the kit.
Just swapping jets will not get you there.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
