Battery question.
Re: Battery question.
23 Aug 2022 16:14Start the bike. Check DC voltage across the battery and rev the engine up to 5000 rpm. If the charging system is healthy, you should get about 13.9-14.5 VDC. If less than 13.7 V, you have a serious charging system problem. If more than 15 V, your regulator has failed, or is about too.So I pulled the battery and it ran 12.6 VDC on the bench. I've got it on a motorcycle battery charger right now. Sounds to me like the battery is fine though. Where do I go from here?
- Qsmothers3
23 Aug 2022 16:26
I can't get the bike running without roll starting it though. That's the problem.
- Qsmothers3
23 Aug 2022 17:29
I think my issue is my starter. It will click but not turn the bike over.
- Qsmothers3
23 Aug 2022 18:14
The starter solenoid clicks just a single time with the key on and pushing the start button. I don't hear the starter motor turning at all. Is there a relay or fuse that could be blown? I really hope I don't need to replace the starter.
23 Aug 2022 18:19
Try jumping the starter relay with the engine in neutral.
23 Aug 2022 23:41 - 23 Aug 2022 23:49
A starter fault would not have caused it to stutter and lose power ( could be more than one thing going on or something effecting both) Connect your voltmeter as follows - black lead to battery ground and red lead to the body of your starter, now push the starter button. If the reading is any more than 0.3v you have a bad ground on the motor
If you look at the third to last page of the guide on the below post there is a fault finding flow chart for the starter circuit
www.kzrider.com/forum/forum-index/faq-wi...-fault-finding-guide
Last edit: 23 Aug 2022 23:49 by Wookie58.
- F64
- 81-KZ440D2
24 Aug 2022 21:30
take a photo of the front of your meter and we'll walk you through the troubleshooting.
81-KZ440-D2.
LIC, NY
LIC, NY
- Qsmothers3
27 Aug 2022 09:53
So I took my starter out and hooked it straight to a battery and it did not spin. That is my issue. Now I have no clue where I'm going to find a starter for this bike.
- JR
27 Aug 2022 10:06
Check your manual on how to service the starter. It may be as simple as opening the top and blowing out crud and carbon dust. It may just require replacing brushes. Make sure you scribe a line between top and bottom before you remove the 2 long bolts and take the top cap off. Its not difficult.
- Qsmothers3
- F64
- 81-KZ440D2
27 Aug 2022 10:39 - 27 Aug 2022 13:00
i'm curious as to why your bike sputtered and lost power while riding though.
how did you hook up the battery to the starter to test it?
81-KZ440-D2.
LIC, NY
LIC, NY
Last edit: 27 Aug 2022 13:00 by F64.
The following user(s) said Thank You: Mikaw, Wookie58
- ckahleer
27 Aug 2022 11:59
Do you have a #3 impact driver?I'm not sure I will ever get these bolts out.
97 ZL600
94 VF750c
94 KE100
82 KZ305
94 VF750c
94 KE100
82 KZ305
