Trike Light Question
  • KZQ
  • KZQ's Avatar Topic Author
  • Away
  • Administrator
  • Administrator
23 Nov 2021 10:48 - 23 Nov 2021 10:54
#858246
Hi Folks,
I'm getting back to finishing my trike project. You can see something about it here:
My problem is how do you wire a three wire tail/stop/turn light to do all three with only two filaments
I'm afraid I'll need two separate/additional lights for either my brake or my turn lights.
Am I missing something? How come I don't find four wire, three filament fixtures available?
Thanks
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Last edit: 23 Nov 2021 10:54 by KZQ.
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Trike Light Question
23 Nov 2021 11:01
#858248
It looks like the one pin is ground and the other two are for high/low.  No instructions?
LED?
  • KZQ
  • Away
  • Administrator
  • Administrator
23 Nov 2021 11:11 - 23 Nov 2021 11:14
#858249
That's right Steve but: How do you manage to shut off the brake light to allow the turn signal to display? Or don't you really need a separate light to function as a turn signal? I'm doing this on a KZ 750 Twin that had separate turn signals.
It seems to me that either:
1) There is a way to wire a two filament light to do all three functions, OR
2) There would be three filament fixtures readily available.
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Last edit: 23 Nov 2021 11:14 by KZQ.
  • SWest
  • SWest's Avatar
  • 10 22 2014
23 Nov 2021 11:22 - 23 Nov 2021 11:22
#858250
I would see if the intermittent pulses would override the the steady on function. I've seen them this way. If not you'll need two more.
Last edit: 23 Nov 2021 11:22 by SWest. Reason: sp
  • SWest
  • SWest's Avatar
  • 10 22 2014
23 Nov 2021 11:29
#858251
After thinking about it a pair of relays one on each might be your answer.
  • slayer61
  • slayer61's Avatar
  • KZR FLAG RELAY CARRIER #62
23 Nov 2021 11:35 - 23 Nov 2021 11:37
#858252
Easy peasey! The lights are connected to the "common of the relay, the brake switch connected to the NC and the signals connected to the NO
Last edit: 23 Nov 2021 11:37 by slayer61.
  • KZQ
  • Away
  • Administrator
  • Administrator
23 Nov 2021 12:11 - 23 Nov 2021 12:15
#858253
OK ! I get it, I think! The 12 Volt source is the blue or the brown wires that previously connected to the turn signals. All I need to find is the intermittent signal from the flasher and connect it.
Do you know the part number for the relays?
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Last edit: 23 Nov 2021 12:15 by KZQ.
  • SWest
  • SWest's Avatar
  • 10 22 2014
23 Nov 2021 14:21
#858261
They're the common ones found at auto parts stores.
  • slayer61
  • slayer61's Avatar
23 Nov 2021 15:23
#858264
Bill
Sorry I never paid any attention to the color of the wire     As an apprentice electrician, my journeyman reminded me that electricity doesn't care what color the insulation is!
And the relays are all the same. You can un plug a Bosch & plug in a Delco and it still works the same.
  • SWest
  • SWest's Avatar
  • 10 22 2014
23 Nov 2021 19:41
#858271
My Chinese top box had a circuit board that switched the spoiler lights to brake, left/right turn and split but it didn't last very long.
File Attachment:
File Name: box2 004.MOV
File Size:4.89 MB
  • KZQ
  • Away
  • Administrator
  • Administrator
23 Nov 2021 19:55 - 23 Nov 2021 19:56
#858272
Ok I see it, mostly, except for the part that says "To Flasher".
Seems to me that that wire must be continuously 12 V positive until a load is applied whereupon it remains 12 V positive but becomes intermittent.
I'm planning to understand all this just before my relays arrive next week.
Thanks for your help.
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Last edit: 23 Nov 2021 19:56 by KZQ.
  • Mikaw
  • Mikaw's Avatar
23 Nov 2021 21:01
#858274
Try the word “from” flasher, and “from” brake switch, makes more sense.
