LED strip - brake/turn same wire
- loves_guitar
29 Jun 2021 10:32
Hey guys,
First off, I totally understand that this mod is outside the scope of restoration. To the purists, I am sorry.
When I received this bike last summer, there were no original taillights. So in my endeavor to turn this bike into a cafe/brat style, I purchased an LED strip for my running, brake, and turn lights. However this strip has a shared turn/brake wire.
Does anyone know how I could modify the wiring to make this work? I have reached out to the company (Mictuning) but have not heard back yet.
Thanks guys.
Thanks guys.
Re: LED strip - brake/turn same wire
29 Jun 2021 13:21
Need to see the rest of the schematic. So far I have
strip Black to bike black/yellow
Strip green to bike gray
strip yellow to bike green
The following user(s) said Thank You: loves_guitar
- loves_guitar
29 Jun 2021 13:29
The bike schematic? It's from the KZ650-H1 Wiring Diagram:
Grey - right signal
Blue - brake
Red - running light
Black/Yellow - negative
Green - left signal
Currently, I wired the blue wire (brake) from the bike to the left signal/brake wire on the LED strip. When the brake is not applied, the left blinker works. When I apply the brake, the left blinker stops. On the right side, with the right signal engaged, the blinker continues with or without the brake applied.
I'm not sure if there is something I can rewire before the rear light to make it or, or if I have to take the light apart and see if I can do some rewiring in there.
Grey - right signal
Blue - brake
Red - running light
Green - left signal
- loudhvx
29 Jun 2021 14:05 - 29 Jun 2021 14:16
To work properly, you will want to use an integrator. They make them for trailers.
You could also just use a few high power diodes to block the brake light from turning the other turn signals on and crosstalk between signals.
If you don't have front signals, and only the ones on the strip, you would only need 2 diodes.
Can you describe the colors of the light strip? Are the signals amber? The brake light should be red, which would mean the signals should be red, but the descriptions seems to indicate white and amber? I don't think it's legal in the U.S. to have a rear pointing white light.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 29 Jun 2021 14:16 by loudhvx.
- loves_guitar
29 Jun 2021 14:19
I bought the strip off of Amazon but it came from this company:
MIC TUNING INC off road,led lights ,auto accessories,online shopping.
There are three colours/rows on the LED strip: red, white, and amber. The running light is red and the brake light makes it more red! The signal lights are sequential using the amber strip of LEDs. The white is not connected as this bike obviously does not have reverse and I have no intention of using it. (I think this company specializes in making light strips for the back of trucks that connect to the 4-way trailer connector.)
I'm comfortable with electrical work but just stumped on this one. Any guidance will be greatly appreciated.
- loudhvx
29 Jun 2021 14:29 - 29 Jun 2021 14:30
Ok, so yes, to get it to work properly, you will need a universal trailer brake/tail integrator.
Or you can use a few or couple diodes, but then the turn signals will not show up when the brakes are applied. I recommend the integrator.
1981 KZ550 D1 gpz.
Other links.
Other links.
Last edit: 29 Jun 2021 14:30 by loudhvx.
- loudhvx
29 Jun 2021 14:36
Something like this I think should work.
www.zoro.com/buyers-products-hd-tail-lig...-5423203/i/G9111459/
1981 KZ550 D1 gpz.
Other links.
Other links.
- loves_guitar
29 Jun 2021 14:37
That's fantastic!! Exactly what I was looking for!
I found this: Reese | 119130 | Taillight Converter (reeseprod.com)
Thank you a 1000 times over! May your beverage be extra cold this evening.
- loudhvx
29 Jun 2021 14:44 - 29 Jun 2021 14:47
That one looks like it would work too, but it also includes wiring for the tail light and grounds.
One note: those blue plastic wire splicers are notoriously flakey. We avoid them as much as possible.
1981 KZ550 D1 gpz.
Other links.
Other links.
Last edit: 29 Jun 2021 14:47 by loudhvx.
- loves_guitar
29 Jun 2021 14:54
Ooooooooh. If I understand you, I do not need all the wires to go through the converter, just the signal and brake wires? The negative and taillight can be wired separately?
And yes, I know those blue splicers are not great. That's why I have my soldering iron set-up on my workbench!
- loudhvx
29 Jun 2021 14:57
It may depend on the unit itself. Some may require that ground wire be grounded in order to work.
The one I linked to doesn't seem to need a ground wire.
The running light probably doesn't need to go through the converter since cars aren't required to have running lights on all the time like bikes do.
1981 KZ550 D1 gpz.
Other links.
Other links.
- loudhvx
29 Jun 2021 15:02
This one on Amazon has a good rating. At least on Amazon you can return it easily. It also has a ground and running circuit which may or may not be required to be hooked up.
www.amazon.com/56130-Non-Powered-2-Wire-...gid=pla-569076551966
1981 KZ550 D1 gpz.
Other links.
Other links.
