LED strip - brake/turn same wire
  • loudhvx
  • loudhvx's Avatar
Re: LED strip - brake/turn same wire
29 Jun 2021 15:09 - 29 Jun 2021 15:26
#850913
You can also make your own with a time-out circuit in case you leave the signal on.
There are a few options on this page, including an integrator you can build. It requires a ground a wire.
s3.amazonaws.com/gpzweb/Lighting/GPZturnSigInteg.html
Last edit: 29 Jun 2021 15:26 by loudhvx.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
29 Jun 2021 16:23
#850916
It would be easier to buy a second LED strip only for the running and brake light.
  • Mikaw
  • Mikaw's Avatar
29 Jun 2021 16:25
#850917
I yeild my time to the experts.
  • loves_guitar
  • loves_guitar's Avatar Topic Author
06 Jul 2021 08:58
#851374
For anyone in the future that wants to know how this turned out:
I ordered a Curt brand non-powered 3 wire to 2 wire converter. I connected the wires, gave it a test.... and it did not work. I should have read closer to the description that the converter I bought would not work for LED applications.
So then I went to the local automotive store and got this Reese converter:  Reese Towpower | 8507900 | Taillight Converter
That worked!
So in case anyone runs into an aftermarket rear light situation where the signals and brake share wires, use a trailer converter!
Thanks, as always, for your help guys!
The following user(s) said Thank You: loudhvx, TexasKZ
  • loudhvx
  • loudhvx's Avatar
06 Jul 2021 09:08
#851375
Glad it's working. Thanks for the update.  That will definitely help others, as more and more questions related to LEDs show up all the time.
  • Oldschoolkz1000
  • Oldschoolkz1000's Avatar
15 Jul 2021 18:23
#851817
If you havent tried to install the trailer box yet, this is definitely a better choice.  shop.revivalcycles.com/led-dual-element-circuit I bought 4 of them for my bike lighting and they work great.
