Time to stock up on spark plugs
- BCScott
Re: Time to stock up on spark plugs
09 Jun 2021 07:11
Speaking of used plugs, does anyone have a good cleaning procedure for cleaning carbon fouled plugs? In the wayback times, I used to have access to a sand blasting machine that you threaded the plug into, blasted it for a couple of minutes and it would come out sparkling clean.
Back in the saddle and loving it! KZ1000A1
09 Jun 2021 08:20
BCScott,thanks for asking. I was thinking the same. I have good, but for fouled plugs. If the stock of B8ES is getting thin I’d like to clean and save what I have.
09 Jun 2021 13:32
I use carb cleaner and a soft brush around the base. Sandpaper between the electrodes.
The following user(s) said Thank You: BCScott
- DOHC
- Those Doe-Hawks really go!
09 Jun 2021 14:18Something like this? www.harborfreight.com/pneumatic-spark-plug-cleaner-32860.htmlI used to have access to a sand blasting machine that you threaded the plug into, blasted it for a couple of minutes and it would come out sparkling clean.
'78 Z1-R in blue
, '78 Z1-R in black,
'78 Z1-R in pieces
My dad's '74 Z1
'00 ZRX1100
My dad's '74 Z1
'00 ZRX1100
- Kaylinator
09 Jun 2021 23:29
I use easy-off oven cleaner. When I first heard about using it, I thought it was dumb until I stopped to think about it for a second.
1978 KZ1000-A2
1978 KZ400-B1
2022 Z900RS SE
1978 KZ400-B1
2022 Z900RS SE
The following user(s) said Thank You: Mikaw, BCScott, Shankkole
10 Jun 2021 07:55
I thought I saw Allen Millyard use a propane torch. Can’t find that video.
- slmjim+Z1BEBE
10 Jun 2021 09:49 - 10 Jun 2021 09:51
The two boxes of ND 24ES plugs we received from OP's vendor (very fast shipping!) appear to be genuine. We examined six plugs, three each from both boxes, very carefully under magnification, comparing them to some NOS W24ES-U and W24ES plugs we've had on the shelf, some for decades. The two 10-plug boxes themselves show legit signs of age and long-term storage. The individual cellophane wrapping of the box each individual plug is in is identical in every way to our old NOS plugs. We're probably set for life on plugs now.
Good Ridin'
slmjim & Z1BEBE
Good Ridin'
slmjim & Z1BEBE
USA
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk
2009 ST1300A
www.kawasaki-z-classik.com
USA
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
Last edit: 10 Jun 2021 09:51 by slmjim+Z1BEBE.
The following user(s) said Thank You: Mikaw, Nerdy, BCScott, krazee1
10 Jun 2021 10:00I’ve been stocking up on NGK. Should be set but FOMO has me wanting in on this. I normally run the B8ES. Should I get the W22ES?$21 (plus tax maybe) for 10 plugs is a pretty fair deal.
These are the original W24ES version, no U which isn't critical. This seller also has 22's which are a little hotter. Equal to NGK B8ES.
- slmjim+Z1BEBE
10 Jun 2021 10:10W22ES crosses to NGK B7ES. Slightly hotter but not inappropriate unless very long runs at high RPM are the norm. We know of some very knowledgeable Z1 owners in EU and AU running B7ES or equivalent.Mikaw post=849957I’ve been stocking up on NGK. Should be set but FOMO has me wanting in on this. I normally run the B8ES. Should I get the W22ES?Nessism post=849656$21 (plus tax maybe) for 10 plugs is a pretty fair deal.
Good Ridin'
slmjim & Z1BEBE
USA
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
USA
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
- krazee1
10 Jun 2021 12:09The two boxes of ND 24ES plugs we received from OP's vendor (very fast shipping!) appear to be genuine. We examined six plugs, three each from both boxes, very carefully under magnification, comparing them to some NOS W24ES-U and W24ES plugs we've had on the shelf, some for decades. The two 10-plug boxes themselves show legit signs of age and long-term storage. The individual cellophane wrapping of the box each individual plug is in is identical in every way to our old NOS plugs. We're probably set for life on plugs now.
Good Ridin'
slmjim & Z1BEBE
Agree! I received my shipment yesterday, and they appear to be legit. Looks like NOS to me, thanks for the tip Nessism!
Mike
1974 Z1
1978 KZ1000 LTD
1976 KZ900B pile O parts
1980 KZ750E
1974 Z1
1978 KZ1000 LTD
1980 KZ750E
- Nerdy
10 Jun 2021 13:35The two boxes of ND 24ES plugs we received from OP's vendor (very fast shipping!) appear to be genuine. We examined six plugs, three each from both boxes, very carefully under magnification, comparing them to some NOS W24ES-U and W24ES plugs we've had on the shelf, some for decades. The two 10-plug boxes themselves show legit signs of age and long-term storage. The individual cellophane wrapping of the box each individual plug is in is identical in every way to our old NOS plugs. We're probably set for life on plugs now.
Mine arrived today, so I'm probably set too - especially because I need half as many per bike.
I am not qualified in any way to assess the NOS-ness - beyond "that looks kinda old" - and I appreciate your analysis.
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
10 Jun 2021 17:04W22ES crosses to NGK B7ES. Slightly hotter but not inappropriate unless very long runs at high RPM are the norm. We know of some very knowledgeable Z1 owners in EU and AU running B7ES or equivalent.
Good Ridin'
slmjim & Z1BEBE
Yup. My 750 runs B8ES or W24ES plugs. I've got a box on the way as well. Can't pass us a good deal. I don't clean plugs.
