77 KZ1000A1 Voltage Regulator
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar
Re: 77 KZ1000A1 Voltage Regulator
03 Jun 2021 05:46
#849529
Mama Kaw went through many iterations of those old regulators due to overcharging.  Some that bench test good will still overcharge because the early ones did that and, when the later iterations of the the old style regulators fail they almost always overcharge, sometimes massively enough to blow light bulbs & burn points to a crisp.  Used ones will be a crap shoot.  They're a little delicate too, as they tend to fry themselves if the battery isn't fully charged to begin with.  They're really just battery maintainers that can't pass much current reliably.
On Z1's they were mounted in a hostile area behind the motor where cooling is a problem.  One of the best things Mama Kaw did for the old regulators was to move them to the side, away from heated air coming off the rear of motor.
We're making the transition to the SH775's on our Z1's as we go through seasonal rotation beginning this year.  A simple pigtail harness will make them plug n' play without butchering the OEM harness, making it simple to revert to original if desired.
Mikaw's  wiring diagram/schematic above is the clearest one we've seen.
Good Ridin'
slmjim
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
The following user(s) said Thank You: BCScott
  • BCScott
  • BCScott's Avatar Topic Author
03 Jun 2021 07:00
#849531
Thanks everyone. I managed to find a NOS OEM regulator for $225 + shipping. Searching last night turned up prices of $135 or so + shipping for SH775 units, with a lot of comments of fakes on eBay, so I decided to stick with the OEM. It's coming from Montana, so hopefully it will arrive quickly.
Back in the saddle and loving it! KZ1000A1
  • Nessism
  • Nessism's Avatar
  • Online
03 Jun 2021 08:21
#849535
I've got a couple of clean and tested SH775 that I resell for $60 each.  These units are super robust so buying used is no risk.
  • Mikaw
  • Mikaw's Avatar
03 Jun 2021 09:21
#849541
Slmjim, the credit for the drawing goes to Nessism. I pulled it from one of his previous posts. I wanted it for my records
The following user(s) said Thank You: slmjim+Z1BEBE
  • slmjim+Z1BEBE
04 Jun 2021 06:37
#849598
Then kudos to Nessism.  Credit where due.  Well done!
Good Ridin'
slmjim & Z1BEBE
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
  • BCScott
23 Jun 2021 15:24
#850665
My eBay NOS OEM regulator showed up today and all is well. It's putting out just under 15v at 4,000 rpm. I'll definitely pm you NESSIM, if this one craps out.
