Capacitor to help with staring?
- Hemmek
06 Apr 2021 15:39
Haven't we all been there?
Those pesky cold starts?
Where the voltage drop is getting severe, motor turns but voltage going low, giving us a weak spark.
Making it even harder to get going.
Maybe we even overchoke her.
Only to have her fire right up after given a jump.
What if.
We install a super capacitor?
Ideally close to the starter.
Wouldt that help out a lot with that voltage drop?
Giving is a much higher chance to get the bike going.
And even when capacitor depletes and we go back to battery only.
It would just be a matter of turning off and charge the capacitor a while.
Right?
So why have I not seen this modification done?
Good idea?
What if.
Right?
Good idea?
Kawasaki kz750 E1 1980
Kawasaki GPZ 900R A1 1984
Re: Capacitor to help with staring?
06 Apr 2021 16:04
A capacitor can give you only a short impulse of voltage power, he charge up quick but discharge even faster.
06 Apr 2021 16:11 - 06 Apr 2021 16:12
I agree with Scirocco. In theory you could do it but (and I haven't done the calculations) the capacitor would probably be bigger than the bike itself. Also, capacitors leak down over time. Assuming it was charged when you shut your bike off....it may well be discharged when you go to start it again. A good battery is a better alternative.
Last edit: 06 Apr 2021 16:12 by hardrockminer.
06 Apr 2021 16:38
+1 good battery
- Nerdy
06 Apr 2021 17:14hardrockminer post=846288I agree with Scirocco. In theory you could do it but (and I haven't done the calculations) the capacitor would probably be bigger than the bike itself. Also, capacitors leak down over time. Assuming it was charged when you shut your bike off....it may well be discharged when you go to start it again. A good battery is a better alternative.
And if it's not discharged, a capacitor that big could ruin your entire day VERY quickly, e.g. if it explodes (as caps sometimes do) or you're working on the bike and accidentally discharge it.
To your other point, even if the cap weren't bigger than the bike, it would probably be too big to be practical.
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
- Nerdy
06 Apr 2021 17:22Hemmek post=846285
Good idea?
I suspect you haven't seen it because there isn't really a need for such a thing.
If someone's bike is difficult to start, that person will most likely try to bring the electrical system back into spec rather than putting a potentially dangerous ancillary item on it.
Having said that, you brought up a good idea - unfortunately just not a practical one. But don't stop thinking about interesting solutions! They're great thought exercises and might even turn into something to build and use.
1980 KZ440B
1981 Yamaha XT250H
1981 GPz550
2013 Yamaha FZ6R
06 Apr 2021 19:16 - 06 Apr 2021 19:24
Assuming it would work, adding a capacitor would be a band-aid fix. Check & set everything as per the factory service manual and especially make sure the battery is good. If necessary, keep a good motorcycle smart charger connected. I have a Ctek US 0.8 smart charger & plug it in whenever the motorcycle isn't being used. My current battery is a Scorpion AGM & is now 3-1/2 years old. The previous scorpion agm lasted exactly 2 years, but I didn't keep it on a charger >> only charged it once a month or so w an old schumacher mc charger.
Last edit: 06 Apr 2021 19:24 by martin_csr.
- DOHC
- Those Doe-Hawks really go!
06 Apr 2021 20:52 - 07 Apr 2021 08:48
EDIT: I made a bad simplification in my math, which made my numbers much worse. I would have failed that physics test. Oops. I've recalculated with what I hope is a less bad simplification, and updated the numbers. Super caps are actually closer to viable than I had initially guessed.
Based on your formatting I was trying to find the rhyme in you stanzas.
The short answer is that batteries (chemical storage) hold a LOT more energy than capacitors (electrical charge storage). And while super caps have really big numbers (Farads!) most of them still don't hold much energy (compared to a battery), and are either very large or have high internal resistance (so you can't get that energy out quickly).
Here is the very long answer:
Random numbers for discussion. What does it take to start a motorcycle? I'm going to say the battery needs to provide 50A for 5 seconds. I'll also assume that (using magic), the capacitor starts at 14V and ends at 10V during the starting event.
You can turn these numbers into total energy required.
Average Voltage: 12 V (lots of hand waving here)
Average Power: 600 W
Total Energy: 3000 W-s, or Joules
So we need 3000 J, and it's easy (or not) to turn capacitance into Joules: hyperphysics.phy-astr.gsu.edu/hbase/electric/capeng.html
Example 1: A coke bottle electrolytic
This is a normal capacitor (not super), but the biggest I could find in stock at digikey.
www.digikey.com/en/products/detail/kemet/ALS70A135QT025/6928375
Size: 8.74" long and 3.5" dia.
Capacity: 1.3F
Using the numbers above (5V drop, 1.3F) I get 62.4 Joules in this big boy. If we had 48 of these on the bike, we'd be all set for one start.
Example 2: A regular old super cap
www.digikey.com/en/products/detail/tecat...BLS-7-5-16-2/9929761
Size: 3.1" x 2.4" x 0.5"
Capacity: 7.5F
So with this you get 360 Joules. You would need 9 of these to get just one start. Not too bad.
Example 3: A hoking super cap
That's not a super cap.... This is a super cap!
www.digikey.com/en/products/detail/eaton...R-16R2507-R/10461228
Size: 16.4" x 6.9" x 2.6"
Capacity: 500F
This time I get 24,000 J, which is actually a lot. That's enough energy for 8 starts. Cool. But it's bigger than the normal battery, costs $600, and will only hold that charge for 7 days due to internal self discharge.
The real answer is lithium batteries. For the same amount of stored energy, they are lighter, smaller, have less voltage drop under load, a higher cycle life, and a wider operating tamp range.
Of course, they also like to blow up, need complicated management electronics, and can't really be swapped directly into a 12V system.
On the other hand, lead-acid batteries are filled with acid which tends to eat the paint off of old KZs, which I personally am really sick of.
But if you're looking to move away from lead-acid, lithium is the direction you should look.
Personally I just buy sealed AGM batteries, bring them inside in the winter, and from time to time put them on a Battery Tender trickle charger to keep them full. They last for years this way.
Capacity: 1.3F
Capacity: 7.5F
Capacity: 500F
'78 Z1-R in blue
, '78 Z1-R in black,
'78 Z1-R in pieces
My dad's '74 Z1
'00 ZRX1100
My dad's '74 Z1
'00 ZRX1100
Last edit: 07 Apr 2021 08:48 by DOHC.
- stone fruit
06 Apr 2021 21:33
Something similar has been developed successfully. Nology Hot Wires. Spark plug wires with a built in capacitor & earth strap.
Nology HotWires Spark Plug Wires Ignition Wires Manufacturer
- Hemmek
07 Apr 2021 00:09
Whoa, got a lot of good answers in a short time
Thank you all
I must clarify one thing thou, I didn't intend to replace the battery
Just helping out with the voltage drop during the starting event.
Also getting more energy to the starter
My actual plan, was to go down the lithium road and mount the battery way in the rear behind the seat, capacitor closer to the starter relay.
As I see there are two advantages.
More CCA (I have not done the math yet but I assume)
And also I am hoping it would smooth out any voltage spikes, extending the lifetime of the lithium.
The biggest problem I see with this solution are actually two.
I would need a second fuse connected on the capacitors + terminal.
And it would add complexity each and every time in working on the bike.
For example taking out the battery over winter will prove quite hazardous.
Since the battery leads will still have plenty potential. Only safe way I guess would be disconnecting the negative battery lead turn on the lights and wait for the capacitor to drain.
Thoughts?
Thank you all
Thoughts?
- Mc Tavish
07 Apr 2021 01:00
Ha ha, Nology HotWires, only for those that still believe in the tooth fairy.
1978 z650C
- slmjim+Z1BEBE
07 Apr 2021 04:57
Voltage drop at coil primaries on older bikes is often caused by the serpentine route through sometimes corroded connectors and often flakey switch contacts that carry current for other loads as well.
If, as often is the case, voltage at coil primaries is less than battery voltage at rest, that can be safely solved with a simple relay, bypassing the main wiring harness & switches to supply coil primaries with direct battery voltage. An example below:
www.wgcarbs.com/index.php/using-joomla/e...-categories/89-coils
Good Ridin'
slmjim & Z1BEBE
Good Ridin'
slmjim & Z1BEBE
USA
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk
2009 ST1300A
www.kawasaki-z-classik.com
USA
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
