Is all B7ES plugs the same?
- katit
24 Dec 2020 19:24 - 24 Dec 2020 19:33
Got a set from ebay without thinking twice, b7es - 11
They don't have thread on ends, so I can't put caps on. Is that a wrong spark plug or what? Is this -11 means its' got "blob" instead of threads?
PS. I did think I can unscrew top to reveal threaded smaller tip but no. I pulled whole thing (unscrewed loktite from within ceramic) It looks like top contact is one piece..
Last edit: 24 Dec 2020 19:33 by katit.
Re: Is all B7ES plugs the same?
24 Dec 2020 19:37
Yeah, they make both types (or at least used to); threaded end and unthreaded.
- katit
24 Dec 2020 19:41
Thanks! Even more sux, don’t see any with threaded ends on bay.
24 Dec 2020 19:49 - 24 Dec 2020 19:50
Look for B7ES/1111 they will be removable top
Be careful ordering of evilbay. NGK has been known to be faked. Your better off ordering from your local auto parts
Last edit: 24 Dec 2020 19:50 by Mikaw.
The following user(s) said Thank You: katit
- katit
24 Dec 2020 20:06
Is b7es just different number for 1111? When I search autozone for b7es they show 1111
Many places show numbers together
Is 1111 ngk is what I need then?
- gd4now
- Denco where did you go?
24 Dec 2020 20:46
No eBay APP ID and/or Cert ID defined in Kunena configurationI would suggest Denso plugs - 3039
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
24 Dec 2020 20:47
1111 is the item/part number. B7ES is the plug number I think. I ordered some and I know 1111 was on the item/part number.
24 Dec 2020 23:39
I buy NGK plugs from a local NAPA store, that way I am confident I a will not get fakes, and can easily return them if there is a problem.
- Mc Tavish
25 Dec 2020 21:18
The 11 refers to the gap, ie, 11 =1.1mm gap.
1978 z650C
26 Dec 2020 09:22Mc Tavish wrote: The 11 refers to the gap, ie, 11 =1.1mm gap.
Thanks, that makes sense because the B8ES have a part number of 2411
- katit
26 Dec 2020 13:55Mikaw wrote:Mc Tavish wrote: The 11 refers to the gap, ie, 11 =1.1mm gap.
Sarcasm?
26 Dec 2020 14:59katit wrote:Mikaw wrote:Mc Tavish wrote: The 11 refers to the gap, ie, 11 =1.1mm gap.
Sarcasm?
Not at all.
