Help with ignition
  • robhartle82
  • robhartle82's Avatar Topic Author
Help with ignition
15 Nov 2020 13:37
#838532
Hey y'all. New to these older bikes. I have a 79 kz400 LTD. The old coil was shot so I bought a dynatek coil. It's a dc8-1 dual coil with 5 ohms resistance. I have two questions: do I need to swap out the ignition points with an electronic ignition? And if so, are there any electronic ignition systems that will work on this bike? I was looking for the dyna s ignition but it doesn't look like they make them for the kz400 . Any help is greatly appreciated.
  • TexasKZ
  • TexasKZ's Avatar
Re: Help with ignition
15 Nov 2020 16:00
#838534
Replace your points and condenser with new points and condenser. If you go with a factory or Dynatek system, you will also need a 2 or 3 Ohm coil.
The following user(s) said Thank You: robhartle82
  • DOHC
  • DOHC's Avatar
  • Those Doe-Hawks really go!
24 Nov 2020 11:32
#838863
robhartle82 wrote: are there any electronic ignition systems that will work on this bike? I was looking for the dyna s ignition but it doesn't look like they make them for the kz400
Here are two threads with some info:
kzrider.com/forum/2-engine/607775-dyna-s...or-a-kz400-which-one
www.kzrider.com/forum/2-engine/597458-19...tronic-ignition-swap
Another thing you could do is use the stock points connected to an igniter box. This would substantially reduce points wear, since it would be acting as a simple trigger.
The Dyna III ignition uses a trigger plate and separate igniter box. It's very likely the box could be used with the stock points as a trigger. Something like this (but I wouldn't pay this price).
TexasKZ wrote: Replace your points and condenser with new points and condenser. If you go with a factory or Dynatek system, you will also need a 2 or 3 Ohm coil.
The Dyna S says that coils need to be greater than 3 ohms. So I think the 5 ohm would work if a Dyna S could be adapted to fit.
My dad's '74 Z1
'00 ZRX1100
  • loudhvx
  • loudhvx's Avatar
24 Nov 2020 13:52
#838882
I have done two Kz400's last year using 7-pin HEI modules and the original points. It's best to use new points to get the most consistent timing, and they will never pit as DOHC said.
s3.amazonaws.com/gpzweb/Ignition/GPZhei7pinModForPoints.html
