Dyna s kit for a kz400 which one
- oldblighty
04 Feb 2018 07:51
Has anyone fitted a dyna s trigger to a kz400 / 440, seems dyna don’t do a kit for the kz400 but reading somwhere it has been done by converting a kit from another kz but which one . Need to get the correct kit for the rotor magnet to fit the 400 advance / retard unit.
Thanks.
Thanks.
- ThatGPzGuy
Re: Dyna s kit for a kz400 which one
04 Feb 2018 08:06
Can't answer your question but have you seen this?
7th Gear
7th Gear
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
The following user(s) said Thank You: oldblighty
- oldblighty
04 Feb 2018 08:23
Thanks for that , I would go for something like this if bike had a battery but need something that doesnt take much juice as running batteryless ignition and need to keep parasitic load to a minimum whilst kick starting , I don’t know if what I am trying to achieve with the dyna s will still give me a spark , it’s a matter of just trial and error.
- Nebr_Rex
04 Feb 2018 09:05
The KZ650/750 plate will fit. the KZ900/1000 is to big.
I used the stock electronic ignition off a KZ750/4.
It is not a bolt on swap.
The timing will be WAAAAYYY off the mark.
I had to use the KZ400 sleeve and turn own the lobe for the points.
Then pulled the lobe off the electronic sleeve and tacked it with a T.I.G.
You will need a lathe and a T.I.G. welder.
A grinder and your buddies 110v welder won't cut it.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- loudhvx
04 Feb 2018 15:35
If you are going batteryless, the Dyna S is not the best suited ignition for that. It is very inefficient at best, and may actually prevent you from starting the bike due to the fact that it wastes a lot of power, right when you don't have any to spare, which is when you are trying to start the bike.
The factory electronic ignition is far better suited for going batteryless. It uses no power until just before a spark is needed.
Even points would be better than the Dyna S for going batteryless, but the factory electronic ignition is still better for that.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- oldblighty
04 Feb 2018 15:46 - 05 Feb 2018 02:24
Hi thanks , it is already batteryless with points setup so Dont want to waste money on an ignition that won’t work , I’ll look for a kz 440 ignition but not many come up for sale across the pond,
I’ll give the wanted section a try see what comes up.
Last edit: 05 Feb 2018 02:24 by oldblighty.
