Finding a Flywheel Rotor for a 1981 Kz1000 Ltd
  • Vintagemoto211
  • Vintagemoto211's Avatar Topic Author
12 Feb 2020 09:28
#819087
While trying to fix a starting issue, I damage the rotor , figuring that that I won't do that again ( fool me once) . I ordered a replacement ( Emgo product for 81-05 Flywheel Rotor, 21007-1036 ) overall dim 119mm OD / 95 mm ID. Surprise it was smaller than the original, did some measurements and it would not fit over the stator.
The old rotor dims are appox:. 130 mm OD / 102 mm ID.. There is no Keyway on the crankshaft and profile for both parts are very similar.
I am going to return the Emgo product since I never removed from it's packaging, it is very well made, I do not believe it is the problem.. Is it possible that the pre 81 KZ 750 rotor will work? Changing out the current stator may work, but I am trying to keep the cost down and would the new rotor work with the a new Stator?.
  • martin_csr
  • martin_csr's Avatar
Re: Finding a Flywheel Rotor for a 1981 Kz1000 Ltd
12 Feb 2020 11:51 - 12 Feb 2020 11:57
#819095
Other than the models listed in the cross-reference at Partzilla, I have no idea if another rotor will work.
I'd guess not on the 750, but that is just a guess.
From the Generator/Regulator diagram at Partzilla for the 1981 KZ1000-K1 Ltd.
ROTOR 21007-1036
Click the part number for the x-ref. A number of models had the same rotor, including the KZ1000P Police models thru 2001.
I would guess you could use the later Police rotors, but that's just a guess. sometimes only a minor change is done to a part.
www.partzilla.com/catalog/kawasaki/motor...e/1981/ltd-kz1000-k1
Last edit: 12 Feb 2020 11:57 by martin_csr.
  • SWest
  • SWest's Avatar
  • 10 22 2014
12 Feb 2020 12:29
#819101
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configuration
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
12 Feb 2020 12:42
#819103
Vintagemoto211 wrote: While trying to fix a starting issue, I damage the rotor , figuring that that I won't do that again ( fool me once) . I ordered a replacement ( Emgo product for 81-05 Flywheel Rotor, 21007-1036 ) overall dim 119mm OD / 95 mm ID. Surprise it was smaller than the original, did some measurements and it would not fit over the stator.
PM Sent.
1982 KZ1100-A2 bike
1984 ZN/ZX1100 motor
