82 Kawasaki kz750m car starting issue
  • Cruzn74
  • Cruzn74's Avatar Topic Author
22 Sep 2019 23:49
#811179
Hello all I have an issue with my bike seems she don't want to start I've watched YouTube video and Google what I thought was the problem so far I've put in the starter clutch also ignition coil and wires along with the starter relay and to no avel she won't start even with the Kickstarter I'll post the video I posted on
YouTube of what it was doing originally any help would be greatly appreciated
  • old_kaw
  • old_kaw's Avatar
Re: 82 Kawasaki kz750m car starting issue
23 Sep 2019 09:41 - 23 Sep 2019 09:43
#811206
I can't tell if it's the starter clutch is slipping or if the engine has no compression . Since I assume it's 2 cylinder engine, it should be making a "thumping" sound as it cranks. Sounds like a no compression issue from the video, if the engine is indeed turning over. A minimum of ~80 - 100 lbs compression is needed for almost any engine to fire.
1981 Kawasaki Kz1000K1
Last edit: 23 Sep 2019 09:43 by old_kaw.
  • loudhvx
  • loudhvx's Avatar
23 Sep 2019 12:46
#811214
The 750 twins have a history of the starter gear slipping inside the actual starter itself. You might get a thump or two, but then it just sounds like a constant cranking sounding like in the video. There are probably a few threads on it on Kzrider over the years.
  • old_kaw
  • old_kaw's Avatar
23 Sep 2019 13:08 - 23 Sep 2019 14:21
#811219
More insight Mr. Obvious. LOL As stated, the starter clutch and start solenoid have been replaced/ fixed. Most all old kaw's have a history of starter clutch failures of one sort or another (mine was loose on the stator) . Some more than others.
Don't miss the part about checking for spark, compression and giving it a shot of ether. Of course it will need to turn over / crank in order to check for any of this stuff.
Starter clutch issue:
And then there's this genius trying to start his bike off of a battery charger. Even a woman will tell you that you need good batteries in your toys. duh.
** Note this youtube video is about 7 years old, and in glancing over the comments, it is STILL a lawn ornament. Soon destined to be a CL special deal.. no title, and the keys were lost somewhere during 2015. lol
Last edit: 23 Sep 2019 14:21 by old_kaw. Reason: hmmmmm
  • Cruzn74
23 Sep 2019 13:29
#811220
Ok so after digging around on the old interweb a little more and Cross referencing my manuals along with feeling more gray hair coming in and some of it coming out on top I still have no spark but tested the pick-up coil and it's supposably"good" according to the manual I need to replace the CDI box also should I be worried about the rust
  • old_kaw
  • old_kaw's Avatar
23 Sep 2019 13:51 - 23 Sep 2019 22:07
#811222
Cruzn74 wrote: Ok so after digging around on the old interweb a little more and Cross referencing my manuals along with feeling more gray hair coming in and some of it coming out on top I still have no spark but tested the pick-up coil and it's supposably"good" according to the manual I need to replace the CDI box also should I be worried about the rust
WOW, now your getting somewhere. No SPARK. Try cleaning up all of the connections to and from all of the ignition devices, along with cleaning / lubing the advancer and see how it acts. Troubleshooting is outlined in the service manual.
Take note on Patton's comments.
www.kzrider.com/forum/2-engine/599802-ig...off-and-idle-surging
The loud one has a fix for the CDI igniter if indeed bad. (it may be ok, just neglected)
Last edit: 23 Sep 2019 22:07 by old_kaw. Reason: typo's
  • loudhvx
  • loudhvx's Avatar
23 Sep 2019 16:28 - 23 Sep 2019 17:03
#811229
Just to be clear, in addition to the starter clutch slippage, there is a pin or something that lets loose inside the actual starter motor so that the motor output shaft does not spin, but the motor still makes noise. That has been a problem for a few people and the symptoms would be similar to the starter clutch slippage. Probably the user named "Steell" has a post about it.
Last edit: 23 Sep 2019 17:03 by loudhvx.
  • SWest
  • SWest's Avatar
  • 10 22 2014
23 Sep 2019 16:54
#811230
old_kaw wrote: More insight Mr. Obvious. LOL As stated, the starter clutch and start solenoid have been replaced/ fixed. Most all old kaw's have a history of starter clutch failures of one sort or another (mine was loose on the stator) . Some more than others.
Take that guy's tools away... And the Kaw. :lol: Obviously it's the starter clutch. :whistle:
  • loudhvx
  • loudhvx's Avatar
23 Sep 2019 17:36
#811233
Actually, the last video shows the inner reduction gearing nicely. About 3:30 into the vid you can see the reducer. I think the big outer ring-gear lets loose and spins, then the planetary gears don't orbit so the output shaft doesn't turn.
  • old_kaw
  • old_kaw's Avatar
23 Sep 2019 22:04
#811246
My 2005 Chevy truck has a permanent magnet gear reduction stater on the 4.3 Vortec engine. The ring gear is plastic, The kaw starter with the metal ring gear looks more stout. This starter will zing the engine over effortlessly. even with a low battery.
Attachment not found
Sorry, I didn't get any pics of the reduction gearing when I went through it.
