Adding water to the battery
  • SWest
  • SWest's Avatar Topic Author
  • 10 22 2014
Re: Adding water to the battery
09 Sep 2019 08:08
#810578
Instead of going through the harness and it's connections the power generated from the stator, to the R/R then to the battery thus the charging system is independent. The battery is being taxed trying to keep up with the lights, Dyna S and green Dyna coils with a charging system putting out intermittent power shown by the multimeter. I may have found the problem.
The following user(s) said Thank You: old_kaw
  • old_kaw
  • old_kaw's Avatar
09 Sep 2019 08:34 - 09 Sep 2019 12:04
#810579
I figured you were overlooking / overcooking something if you are destroying new batteries in less than a year, no matter where they are made.
If you isolated the stator wiring from the main harness doesn't really make it a independent system any more than one with the yellow wires still taped into the main harness. The thing that makes it somewhat independent is it's >not< needing the brown sense voltage to control charge voltages. I do hope the missing stator phase didn't damage any of the rectifier diodes in the SH-775. I doubt it, but electricity can be funny like that.
I don't think I've seen a miniature analog meter like that in 20-30 years. A customer I repaired a dining room light for yesterday had a large Micronta (Radio Shack vintage) analog meter vintage mid 80's that was the large version of your little meter. My digital multi-meter is a HF $20.00 special, after I smoked out my good digital meter checking out a mercury vapor ballast, that made my long time digital meter turn into vapor. poof. :pinch:
Attachment not found
I can't make much out of the videos either, (cough, choke, grunt, cough, good kitty, hack.. lol) so I just forgo it hoping that you will type out a summary of your findings. BUT, all of your healthy living does look to be paying off BIG! More soda and cigarettes please. :-)
1981 Kawasaki Kz1000K1
Last edit: 09 Sep 2019 12:04 by old_kaw. Reason: typo's
  • SWest
  • 10 22 2014
15 Oct 2019 11:40
#812516
Don't like soda. :sick: I found the problem. :woohoo:
  • old_kaw
  • old_kaw's Avatar
18 Oct 2019 08:14
#812659
I could only see your meter display briefly in your video (as usual), but from what I could see, it looked like it was charging ~14.59 volts under load. This seems a tad bit high to me, which may still cook your batteries. I am assuming you still have the SH775 R/R (non-adjustable) that uses no sense feed (brown wire) except the output wire. Perhaps you still have some flaky connections between the battery and the regulator causing the output to run high?
