83 KZ550 LTD can’t get new lights to work.
  • CSETHOVER
  • CSETHOVER's Avatar Topic Author
26 Jul 2019 15:41
#808199
I got new turn signals and hooked them up. When I turn on the power the front light up but the rear do not. When I switch on a the blinker the corresponding rear turn signal will light up and stay on. When I plug in the old turn signals they work just fine. I’m not sure where the issue is coming from.
These are the new signals I bought BESONDER 2Pcs Heavy Duty Motorcycle Bullet Turn Signals Blinker 3 Wires Indicator Lights Amber Lamp (Black) www.amazon.com/dp/B07L5PCM3Y/ref=cm_sw_r_cp_api_i_BA1oDb0R7M26P
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: 83 KZ550 LTD can’t get new lights to work.
26 Jul 2019 15:50
#808200
Looks like you get LED rear lights. LED Need the right +/- polarity to work properly. Try to Switch the connectors.
  • martin_csr
  • martin_csr's Avatar
26 Jul 2019 16:14 - 26 Jul 2019 16:16
#808203
Also, you may need to get an electronic turn signal flasher & hazard flasher. Autozone & other places carry Novita flashers & they fit the same as the stock thermal flashers. Novita = Made in USA.
Novita Turn Signal Flasher. Tridon® EL12. Electro-mechanical flasher.
Novita Hazard Warning Flasher. Tridon® LL552®. Made in USA.
Novita flashers
Last edit: 26 Jul 2019 16:16 by martin_csr.
