sudden failure while riding
  • loudhvx
  • loudhvx's Avatar
Re: sudden failure while riding
27 Jun 2019 08:07
#806558
These bikes did not originally come with inline filters. They usually have a screen integrated into the petcock assembly, so some purists might do without an inline filter. Adding one shouldn't hurt, as long as it's not a paper-element filter for cars (which have fuel pump pressure). Metal screens or scintered-brass elements do okay with gravity feed.
The following user(s) said Thank You: KzRyan
  • KzRyan
  • KzRyan's Avatar Topic Author
  • Ryan
27 Jun 2019 09:00
#806561
The Pingel I use has a screen I’m pretty sure. Pushes over the inlet spout inside the tank. I feel several years ago I went around and around about using an Inline filter and choosing to use one saved me some carb cleanings. They are cheap and if I do it right no one will see it ...easily.
1978 Kz1000 A2A. 1040 Weisco 10.25:1 pistons, VM 28ss carbs, Dyna S Ignition and coils, Moto GP Werks exhaust, Ikon Shocks, lithium ion battery, Always a work in progress.
1974 Kz400 - 16K miles - all stock
  • KzRyan
  • Ryan
28 Jun 2019 18:33
#806651
So the quick carb clean did the trick! Last night I changed spark plugs, added a steering damper and today I got 60 miles in. Good stuff. Did not install an inline filter. Have one coming via the amazon tomorrow, I’ll keep it aside Incase I need it later. Thanks for the advice guys!
  • SWest
  • SWest's Avatar
  • 10 22 2014
28 Jun 2019 20:23
#806652
Install it as soon as you get it.
  • KzRyan
  • Ryan
29 Jun 2019 11:37
#806675
Do you have one yourself? I’m wondering (and wondered in the past) if I should try my best to have the inline filter going vertical into the center carb inlet. Or if having it horizontal in the fuel line closer to the petcock is fine.
  • SWest
  • SWest's Avatar
  • 10 22 2014
29 Jun 2019 13:08
#806680
Yes, I have two, one on each line.
