Ground ... Where is the Ground? Also. Women.
  • chopper1963
  • chopper1963's Avatar Topic Author
12 Jun 2019 14:41
#805591
1981 GPz550.
I think I might have screwed up by powder coating the frame ... where are the grounds for the wiring harness?
I can read women's moods pretty well but I can't read a wiring diagram to SAVE MY LIFE.
Where should I look with my eyes to make sure the system is grounded?
thanks
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Ground ... Where is the Ground? Also. Women.
12 Jun 2019 14:59
#805592
On the case Right lower side. 10mm hex head bolt. Battery negative and harness ground.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
12 Jun 2019 15:20
#805595
If the engine case is bolt in rubber damper into the frame you need an extra negative (ground) terminal wire to the frame.
  • chopper1963
12 Jun 2019 16:24
#805599
In right side do you mean front brake lever side or?
I see this ground on the back of the engine case. Is this what you are referring to?
Pic attached. Hopefully.
  • chopper1963
12 Jun 2019 16:26
#805600
<<f the engine case is bolt in rubber damper into the frame you need an extra negative (ground) terminal wire to the frame. >>
I don't understand. How would one do this?
  • SWest
  • SWest's Avatar
  • 10 22 2014
12 Jun 2019 16:55
#805604
That's it but you can run the harness ground to a frame bolt or battery.
  • loudhvx
  • loudhvx's Avatar
12 Jun 2019 19:26
#805615
The big negative battery cable goes to any of the rear clutch cover bolts on the engine. I use one near the top rear. From there I run a 14ga to a bolt on the frame near the battery box hangers. Then I attach harness grounds to that bolt.
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar
13 Jun 2019 06:59
#805644
chopper1963 wrote: ...I can read women's moods pretty well...
Don't know if this vintage analog device is available any longer but, once set correctly, it has been invaluable for it's intended purpose.
It never worked well on hormonal 'tween girls though...
Good Ridin'
slmjim
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
The following user(s) said Thank You: jlaudiofan
